passenger HID sometimes does not work
Old Jan 15, 2012 | 06:30 PM
itz_joker_xl's Avatar
when i first turn the car on only the driver side comes on. then when i turn my lights completely off then turn them back on they come on fine. i have no idea what the problem is. i replaced the ballast once already.
Old Jan 15, 2012 | 06:48 PM
bratboy90's Avatar
Aright noob, helps if you give us some slight details.
Year
Make
Model
Brand of HID's
Did you have to splice wires with that kit or directly plug and play?
However, I can say from my experience with my Ion Redline, my drivers does this once and a great while. I theorize it has something to do with the cars being extremely sensitive to ohm and watt changes. Try changing the fuse to them, and make sure A. the polarity on the ballast is correct AND B. The connect is tight(NOT LOOSE AT ALL) Could possibly be due to condensation if you didn't electric tape the hell out of the connections.
Old Jan 15, 2012 | 07:05 PM
heathkidder's Avatar
Reground it
Old Jan 15, 2012 | 07:08 PM
srry no need to be an ass about it
2006 2.4 ss 10k hids plug n play. i got them at buyHIDs.com
Originally Posted by heathkidder
Reground it
i have no idea how to do that
Last edited by itz_joker_xl; Jan 15, 2012 at 07:08 PM. Reason: Automerged Doublepost
Old Jan 15, 2012 | 07:13 PM
chingajose's Avatar
are you using a relay harness?
Old Jan 15, 2012 | 07:31 PM
no
Old Jan 15, 2012 | 07:50 PM
TommyP's Avatar
AWD > FWD
You need to run relay harness with hids or you'll keep having this issue. Also pull your drl fuse if you haven't already
Old Jan 15, 2012 | 07:56 PM
LaserBlueCobaltSS's Avatar
Yes you have to run a relay harness.
I just put my hids in my depo projectors yesterday and i got the relay harness with my kit from buyhids.com..
I pulled my DRL fuse too..
You need to do these steps so you wont have issues like that!!
Old Jan 15, 2012 | 08:00 PM
k thanks guys. i am a noob so does DRL stand for Day light running lights?
Old Jan 15, 2012 | 08:03 PM
can you post what relay hardness i need to get
Old Jan 15, 2012 | 08:04 PM
Day time running lights!
Old Jan 15, 2012 | 08:06 PM
Just go to buyhids.com and get one from them..
Old Jan 15, 2012 | 08:20 PM
chingajose's Avatar
bingo needed a relay harness. lol
Old Jan 15, 2012 | 09:51 PM
DCOBALTSS's Avatar
i had these problems before even with the relay did the same thing.. new ballast same thing..
Decided to run my hids 9007 low beams only and no relay guess what: works great
Old Jan 15, 2012 | 09:59 PM
Mike Casey's Avatar
have the same problem ive just dealt with it havent gotten around to fixing it
Old Jan 15, 2012 | 10:50 PM
nobody2u's Avatar
What side effect does pulling the DRL fuse have? Do they not come on automatically anymore or something?
Old Jan 15, 2012 | 10:55 PM
TommyP's Avatar
AWD > FWD
You don't have daytime running lights. That's it. The daytime running lights run the low beams at half voltage which can damage hid systems and cause issues.
Old Jan 16, 2012 | 09:05 PM
my turn signals are the DRL's it is a 06 so what do i need 2 do know just get a relay harness?
Old Jan 16, 2012 | 09:06 PM
TommyP's Avatar
AWD > FWD
yes just get a relay harness.
Old Jan 16, 2012 | 09:41 PM
can someone find me a cheap eBay relay harness the ones from buy hids are freaken 26$. i dont want 2 buy the wrong kind
Old Jan 16, 2012 | 10:00 PM
chingajose's Avatar
the ones on ebay r cheap. they r made cheap. for the price and made better. i got the trs one and it is made very good. good quality.
Old Jan 16, 2012 | 10:18 PM
Xenon HID Conversion Kit Relay Wiring Harness Wire Upgrade Pack For H4 9003 HB2 | eBay
this is the one i am going to get i dont have bi xenon
Old Jan 16, 2012 | 10:36 PM
mkulrey13's Avatar
PM us and we can do a deal for you for a relay harness.
Old Jan 16, 2012 | 10:59 PM
but all you guys have is bi xenon i need a reg xenon 1
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
