Passenger side lights dim??
Old Jun 18, 2008 | 01:40 AM
06BrandonSS's Avatar
I was driving home from work a few minutes ago and pulled into the driveway. I look at my headlights on the garage door and the passenger side looked like it was out. So I got out and looked and found the headlight and turn signal lights were dimmer than the drivers side. I searched but found no one having this problem. Could this be a ground issue or??? Im not much of an electrician just guessing. Im going to look at it tomorrow if I dont find anything its going to Chevy. Thanks for any help. One thing my headlights are painted inside but havent been out in a week. I just put a 3" cold air intake on today but thats on the drivers side.
Old Jun 18, 2008 | 10:40 AM
bump im getting ready to check this out
Old Jun 18, 2008 | 11:18 AM
Nichq's Avatar
There are fuses for left and right headlights. They are on the fuse panel under the hood. You might want to check those.
Old Jun 18, 2008 | 11:21 AM
BigTizzle903's Avatar
even if they are good i'd just replace the passenger side anyways and see if it makes a difference, fuses arent that expensive
Old Jun 18, 2008 | 02:32 PM
alright thanks Ill try that
edit: found the problem, when they guy custom did my intake he took off the ground wire near the intake tube and then ******* decided to ground it to the plastic headlight bracket and lost the bolt. i went to the hardware store and matched it up as close as possible and they work fine. thanks for the help all.
Last edited by 06BrandonSS; Jun 18, 2008 at 02:40 PM. Reason: Automerged Doublepost
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
