philips hid kit?
Old Dec 10, 2010 | 10:52 PM
NOLAGSS's Avatar
philips hid kit?
seen these around on ebay for about 130 shipped.. correct me if i am wrong but phillips puts hids factor in some vehichles correct? not a bad price if its going to be the same quality as some oem hids. any thoughts on this
Old Dec 11, 2010 | 12:48 AM
TommyP's Avatar
AWD > FWD
Yes, Phillips and Osram are the two major manufacturers for OEM suppliers. Be careful though, there are a LOT of Phillips imitators.
Old Dec 11, 2010 | 12:55 AM
ecot3c inside's Avatar
no it is different. philips and phillips are different companies they get away with it because of the spelling.
Old Dec 11, 2010 | 01:07 AM
TommyP's Avatar
AWD > FWD
I wasn't even looking at spelling. Gotta be careful with that.
Old Dec 11, 2010 | 09:28 PM
tomj77's Avatar
one l is correct or 2 for real philips?
Old Dec 11, 2010 | 09:31 PM
tomj77's Avatar
i got some philips hids, were about 250, other than the fact that 1 bulb was defective, which they sent me one in the mail right away when i called them, they are pretty awesome hids. 2 year warrenty with the relay/highbeam controller harness, even the drls work at full low beam power.
philipsxenon dot (u know the rest.)
Old Dec 11, 2010 | 09:33 PM
Nighthawk243's Avatar
Phillips does not make aftermarket kit ballasts that are plug and play.
Old Dec 11, 2010 | 09:42 PM
TommyP's Avatar
AWD > FWD
True, but you can buy rebased Phillips bulbs. The retrofit source sells H1 rebased bulbs.
and Tom, it's 2 Ls. PHILLIPS.
Old Dec 12, 2010 | 02:57 PM
NOLAGSS's Avatar
pretty good info i was just curious. i had a bad flicker with my hid bulbs that came with my headlights but i just istalled some 5k bulbs with new ballast and am very happy no flicker either. o and by the way i googled how to aim projectors and this is how it went
1. measue from ground to center of projector
2. measure from center of one projector to the center of the other i think my measurments were 4.2 for width and 2.7 for height not positive the
3 tape on the door the hieght and width and then tape again 2.1-2.5 inches blow that mark.
4 back your vehichle so the headlights a re 25 feet from wall or garage door and ur headlights should be at the lower tape marks for a .04 drop which is dot standard.
well mine were hitting the top of my house lmao so i aimed them which spite what everyone else says was really easy took me all of 20 minute (gen 1 projectors) now they look great
dennis69
Oct 20, 2015 04:49 PM
thewafflesareburnt
Sep 30, 2015 02:29 AM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
