Plasti Dip interior pieces
Old Jul 11, 2011 | 04:40 AM
SatanzSS/SC's Avatar
i just bought 2 cans of plasti dip and will be doing the interior pieces, evo mod, and whatever else my imagination helps me come up with. i just wanted to know if anyone has plasti dipped their interior pieces? ive searched and havent found anything.
Edit: Well seeing as how I haven't gotten a yes from anyone, I will use my car as the test subject to see what the interior will look like. Ill be removing all the trim pieces later today and hopefully have them sprayed by tonight. Ill keep you guys updated with plenty of pics.
Last edited by SatanzSS/SC; Jul 11, 2011 at 07:05 AM. Reason: added more info to the op
Old Jul 11, 2011 | 04:46 AM
cmatthewb101's Avatar
Not that I know of. So subbed for results
Old Jul 11, 2011 | 05:49 AM
Erick161's Avatar
prob not because its a dull finish....unless you top it with a clear, but still wouldn't come out piano black I wouldn't think. would need some real automotive clear coat.
Old Jul 11, 2011 | 06:10 AM
devon9832's Avatar
interested in the outcome... sub'd
Old Jul 11, 2011 | 07:01 AM
I actually like the flat black color on cars. I think it'll actually turn out pretty good. Only way to find out is to do it.
Old Jul 11, 2011 | 07:08 AM
Godly's Avatar
I seen a thread on here the other day where somebody had done that, actually 2-3 people, just search for it. I did my front lip in it the other day!
Old Jul 11, 2011 | 07:11 AM
I did search and came up empty. All I could find was plenty of plasti dip evo mod threads. Either way I'm doing it.
Old Jul 11, 2011 | 07:25 AM
BlackARCA06's Avatar
Its gonna leave a rough finish. Not smooth.
Old Jul 11, 2011 | 10:33 PM
Wink
Ok so iremoved all the panels I was going to plasti dip and instead of spraying them all, I only sprayed one panel and it turned out rough just like BlackARCA06 said it would. Here are a few pics.
My next question is would it actually turn out smooth if I sand down the silver off the pieces? Some of them have a lot of chunks of silver missing on them anyway.
Old Jul 11, 2011 | 10:35 PM
JustACobalt's Avatar
if you are going to sand down the silver anyway and cross the line of irreversability, you might as well just spray paint it with black enamel..
Old Jul 11, 2011 | 10:42 PM
LS6Rally's Avatar
No sanding it will not make it smooth. plasti dip is meant to be textured.
iboost's Avatar
^This
Old Jul 11, 2011 | 10:50 PM
Well now that I peeled off the plasti dip, I DO NOT, I REPEAT DO NOT RECOMMEND THE USE OF PLASTI DIP ON INTERIOR PIECES! This is the outcome of using it on the interior pieces.
Now I have no choice but to sand and spray with enamel. Oh well!
Old Jul 11, 2011 | 10:53 PM
Phyrric's Avatar
I plasti-dipped my entire wing blade and peeled it all off in one sheet cause I fucked it up, you have to apply this **** on thick with one coat, you cant treat it like normal spraypaint with little thin coats if you want it to peel off, and they have to be super clean.
nicholass balls's Avatar
Damn :/
that's GM for ya.
Old Jul 11, 2011 | 10:56 PM
donkeyballs's Avatar
I seen this thread and i thought that would happen lol.. I would of said something if i seen it sooner.
Old Jul 11, 2011 | 10:57 PM
idk if its because the exterior parts that get plasti dipped regularly by everyone have the clear coat as a protective barrier between the paint and the plasti dip or what. we all know that the silver paint used by GM for the trim isnt good at all.
Old Jul 11, 2011 | 10:59 PM
no harm really cuz i was already wanting to paint the trim anyway. experience is the best teacher.
Old Jul 11, 2011 | 11:02 PM
Phyrric's Avatar
Oh yeah the silver is garbage, Mine chips if I have the AC blowing too hard on it
Old Jul 11, 2011 | 11:03 PM
yep there are alot harder mistakes to learn than that haha
Old Jul 11, 2011 | 11:04 PM
i wouldnt doubt it either.
N1ckateen's Avatar
i sanded my interior peices then used plastic primer then once it dried i wet sanded it and it was very smooth then i used flat black acrylic enamel and put 3 good coats on it and they turned out flawless. almost looks factory. been like that for a good 6 months now and not a single chip!
Old Jul 11, 2011 | 11:06 PM
Yep! I have been trying different stuff with the interior pieces and i noticed it chips off easy but your better off with real paint anyways.
Old Jul 11, 2011 | 11:10 PM
i agree. but the reason for me trying plasti dip is because of the fact that you can peel it off if you dont like it and i wanted to see what the interior would look like black.
looks like ill be going that route now aswell.
Last edited by SatanzSS/SC; Jul 11, 2011 at 11:10 PM. Reason: Automerged Doublepost
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
