Plastic to plastic bonding and forming?
Old Jan 13, 2011 | 02:49 PM
07BoostedG5's Avatar
Hey guys I spent the last couple days going store to store looking for the right product, What I need is a plastic to plastic bonding agent, that can build up structurally and be able to sand and paint, any ideas? Im trying to avoid fiberglass due to the mess and fumes etc... also has anyone used Goop?
Old Jan 13, 2011 | 04:22 PM
Ricer's Avatar
check out 3M Automotive Automix line.. you'll find what you're looking for there. Fusor automotive adhesive products are also good. Any automotive paint supply store will carry one or both of them
Old Jan 13, 2011 | 04:25 PM
Thanks
Old Jan 13, 2011 | 04:29 PM
ItalianJoe1's Avatar
3M makes a ton of stuff that will work. Just about any bondo type epoxy will work, I filled a valve cover with a combo of bondo and epoxy putty the other day (in different spots, not mixed together), came out really nice.
Old Jan 13, 2011 | 05:39 PM
And most of this stuff will be found at a paint and body store huh? not the regular auto parts places, since all I find there is small containers and mostly glass supplies
Old Jan 13, 2011 | 09:02 PM
JoshuaVnyrd1817's Avatar
You need to go somewhere that sells actual Auto Paint. Auto Zone, Murry's, or Advanced Auto are not going to carry what you really need. Auto Value is what is the most popular around here.
Old Jan 13, 2011 | 09:05 PM
I was talking to one of my fellow fabricators, and I may just use JB plastic weld epoxy seems like it will do the job.
Thanks again for all the input.
Old Jan 13, 2011 | 09:21 PM
LS2SS's Avatar
If u want good paint try an English Color store if there is one near u
Old Jan 13, 2011 | 09:23 PM
I need to google that one, never heard or seen one, I see your dfw so they may be one in Houston
Old Jan 13, 2011 | 09:32 PM
LS2SS's Avatar
there should be, my dad buys from them every day for his business very cool people
Old Jan 13, 2011 | 09:36 PM
SSSnoop's Avatar
I've used a 2 part epoxy specifically for plastic parts with a lot of success - although the smell from it is a bit unholy (I'd take fiberglass resin smell over it any day). That, and most of the plastic epoxies/builders take around 8 hours for a real good cure.
A bit of advice - prior to doing any bonding on plastic auto parts, be sure to roughen the surface slightly (of course), but also grinding back slightly on cracks promotes better adhesion, and use a plastic prep solvent to help promote the adhesion and get rid of any trace of wax or plasticizer bloom.
International Epoxies makes some good two part and carries the solvent - if you can find the stuff by you. They're out of Florida:
Plastic repair items for the automotive repair industry from IES 800-451-7206
They also carry the solvent cleaner.
3M also has a good one - the 4240 is good for slightly flexible stuff like bumpers, but it takes a special gun to apply (good if your cuz works in auto body, like mine ).
jcalvin1126
Oct 26, 2015 12:31 AM
dennis69
Oct 20, 2015 07:39 AM
hawkssoccer11
Sep 30, 2015 12:14 PM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
chris88z24
Sep 8, 2015 01:55 PM
