Powdercoating Supercharger
Has ANYONE done this? Concerned about bearings and heat. Anyone at all?
Need to get some insight asap since my SC is off right now.
please help me out i know there has to be someone who has done this.
i know a few different people have done this. me being one of them. i did it 2 years ago and no problems yet. just make sure you take that rubber/plastic piece off inside the snout. drain all the fluid. if there is anything else that needs done i didnt do it and havent had any negative effects from it yet.
you gotta take it apart. i really wanted mine powdercoated but im not taking it a part. i think im going to paint it.
thats if BYT messages me back regarding install. no email no install. no install no going boosted!
Im actually still trying to figure out how the hell to get the peice that connects to the end of the snout that holds the pulley to come off. I got the pulley itself off...but no dice yet on that peice. There must be a way without ordering a tool. I just havent figures it out yet.
the hub is pressed on. you can just use a press if you dont have the tool to take it off (thats if you have shop access or a press at home) also when i coated mine i cant remember but i believe i took the rotors/blades/ what ever everyone else calls them out. (i had taken the whole thing apart to inspect it as i just bought it used right before i powder coated it. i did NOT remove any bearings though
Eaton M90 Supercharger Snout Rebuild: Part 1 - YouTube
Eaton M90 Supercharger Snout Rebuild: Part 2 - YouTube
didnt i say i powedercoated mine 2 years ago and its doing fine? if you dont believe me go do a search. i bought the blower from hatrickstu 2 years ago. i then have posts about me powdercoating it.... pretty sure if they couldnt handel it sometime over the past 2 years something would of failed.
z28addiction
Sep 28, 2015 12:03 AM
