Power Window Idea...
you know how our power windows have the one touch down for the drivers side?
well i think im getting a whole new driver side motor assembly bc of my accident, so how hard would it be to integrate a 1 touch button in the drivers door panel that controlled the passenger window
worst case, wouldnt it make them go down at an even speed?
or is this not feasible?
in therory it would work i think the 1 touch works with a trigger switch in the window but im not 100% sure i have seen some of the people with f150's do it before so i think its possable again not 100% sure about it on our cars if it is possable i would like to do it also
Originally Posted by DanJHartman
lol the thing that pisses me off is that the passanger side motor rolls the window up and down so much slower
i would use the old driver side motor, and i assume it would work just as fast
15.742 a guy runs in a sedan which is on tape but when a coupe runs a 15.6 people make a huge deal .
but n e who. I think it would work. no reason why it wouldnt work. so lets see it already
Better make sure the driverside and pass side motors will interchange, im not so sure that they will.
The automatic down on the driverside is all in the switch. I know this from exp... my 89 Z24 wnd switch went bad and since i work at a junk yard i snagged a switch out of a late 90's cav, with a little splicing of the wires and a little trimming of the consol i upgraded my 89 cav to a 99 setup with auto rolldown driver wnd.
If some one finds a way to auto open and close the sunroof that would be great.
Our cars electrical systems are all controlled by a Body Control Module. I'm not certain, but I don't think the window switch has anything to do with it. If you put a one touch switch on the passenger door window, the BCM probably won't work with it.
and get my car back from the collision shop, its takin foreverrrrrrrrrrr
Originally Posted by bhowman1980
Well there is only one way to find out try it!!! i'll get aroung to it this weekend weather permitting. The auto down feature is in the switch. TRUST ME the normal switch operation is a simple momentrary switch and the auto down(when you press the switch a little farther down) is a full open circut. Body control modual doesn't controll this aspect of the wnd operation check wiring diagrams of the last decade gm cars with the auto driver wnd!!! but by all means prove me wrong and i will gladly shutup wait till monday and i will get back with youall if its possible or not! maybe someone can get a part # on the driverside wnd switch
i just got all the motors and stuff, so im anxious to put it in
anyone think it can be done?
my buddy did it in his silverado, so im hopin i can do it in my cobalt
I'm tending to agree with Halfcent on this one, Nothing in the car actually runs off the switchs, the switches run to the Computer and it send a signal back....But if I'm wrong I would love to have express windows all around, including that pesky sun roof....
I can't prove you wrong because I don't have the schematics. But I know that the "last decade" of cars argument doesn't work. The Delta platform is a completely different electrical beast. In 2005, GM went with Body control modules and LAN's troughout the cars to control everything. There is a high speed and low speed Local Area Network running through your car carring signals to everything. Nothing is directly connected to a switch.
