Projector L.E.D Problem
Old Oct 27, 2007 | 10:55 PM
NP05Cobalt's Avatar
Question Projector L.E.D Problem
My three L.E.D's on my projectors don't work on driver and passenger side headlights, what could cause this? The halo rings work and everything but the 3 L.E.D's don't, I tried fixing them all day and nothing happened...but anyways, Any help would be great!!
Old Oct 27, 2007 | 10:57 PM
exiged's Avatar
did you try replacing the LED's themselves?
Did they all go out at the same time?
Old Oct 27, 2007 | 10:59 PM
NP05Cobalt's Avatar
i swapped bulbs around from sides and i could get 2 on the passenger side to work and no more then i swapped em again and now none working...eh
Old Oct 29, 2007 | 01:43 PM
NP05Cobalt's Avatar
bump...anyone?
Old Nov 26, 2007 | 02:11 PM
NP05Cobalt's Avatar
bump...still got this problem
Old Nov 26, 2007 | 02:14 PM
StoryoftheYear's Avatar
thats exactly why i got rid of my projectors.....those leds just burn out/ dont work left, right and centre
Old Nov 26, 2007 | 02:56 PM
NP05Cobalt's Avatar
nobody can help me out with this?
Old Nov 26, 2007 | 03:12 PM
Edub83's Avatar
Were you replacing hte LEDs or did they just all of a sudden quit working? Is it possible that you got the LED poles reversed and thus causing the LEDs to not work?
Old Nov 26, 2007 | 03:19 PM
refuge4's Avatar
I would remove the LED bulb and rotate it 180 degrees. Put it back in and then try it all over. Are these the original LED's or something new? Have these ever worked or is this the first time you installed them?
Old Nov 26, 2007 | 03:57 PM
NP05Cobalt's Avatar
these are the originals and when i got the headlights from another member here i had to hook them back up as he didnt like them... and they worked but then i dnno what happened... i know one of my halo LED's are out as im replacing it tonight but the LED's all are good as i can get one side to work and not the other
Old Nov 26, 2007 | 04:53 PM
refuge4's Avatar
If you are having issues with the 3 LED's on one side of the vehicle, but when you change them they work on the other side, your do not have a good connection in your wiring. Put three 194 bulbs in the sockets of the side that is not working. If the lights come on, then you have an issue with your LED's. If they do not come on, then you have an issue with your connections.
Old Nov 26, 2007 | 05:27 PM
NP05Cobalt's Avatar
okay ill try that tonight...thanks
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
