projector light questions
Old Jan 14, 2009 | 11:12 PM
AdamJay's Avatar
was thinking about buying some projector lights i already baught my hid kit. (well the girlfriend did ) and i need to know if i buy the projectors will the hid's still fit? not sure if the bulb hole is the same...sounds dumb i know but want to reinsure myself before i buy them, and aslo i noticed most projectors had two "eyes" what is the second one used for?
im a newb i just read another thread said they wont fit...why wont they?, what do i need to buy then? and whats the difference between 1st gen 2nd gen and 3rd gen projectors?
Old Jan 14, 2009 | 11:41 PM
Xavipheus's Avatar
The standard stock bulb is a 9007, but the projectors use H1's soo...no they wont work together
Old Jan 14, 2009 | 11:50 PM
AdamJay's Avatar
ok so can i just buy hid bulbs instead of a whole new kit?
Old Jan 15, 2009 | 03:05 AM
zay52790's Avatar
yea, you can just buy a set of h1 bulbs and it will work
Old Jan 15, 2009 | 03:24 AM
liljone's Avatar
I have 9007 projectors with a H1 hid kit so I drilled a bigger hole and it worked
Old Jan 15, 2009 | 03:34 AM
rrauter's Avatar
and the 1st gen and 3rd gen aren't plug and play... you have to wire the halos and leds but thats easy so dont worry. the 2nd gen are nice because they are 100% plug and play and the halos are CCFL so much brighter. i personally like the gen 1 but its your choice.
and yeah new bulbs is easiest fix if you get the projectors. i love mine and i have the 3b spec hid kit.
oh and ps... gen 2 has an H7 bulb size, gen 1 and 3 have H1 bulbs
Old Jan 15, 2009 | 03:45 AM
CruzinYellow's Avatar
Well I have the 1st gen projectors and my halos and led's came prewired. All I had to do is put in the bulbs provided with the kit and connect harness to stock harness in the car removed previously from old headlights. I know the low beam (outside projector) was H1 for sure not sure about the other bulb which is actually for your high beam (middle light non-projector) to answer one of your questions. I had purchased an HID kit, mounted the ballast under the headlight and the bulb fit perfectly where H1 bulb was supposed to be. The clip held the bulb in place just fine. Eventually the Halos and LEDs begin to burn out and I have since replaced them very easily I might add and changed the colors. Check my image gallery if you would like to see how they look. If you have anymore questions or I left something out let me know.
Old Jan 15, 2009 | 12:28 PM
AdamJay's Avatar
how do you know if there 1st 2nd or 3rd gen?
Old Jan 15, 2009 | 12:32 PM
RedEcotecSS's Avatar
searching.
Old Jan 15, 2009 | 01:14 PM
rrauter's Avatar
1st gen have the two halos side by side with the 3 LEDs in the inside corner with the blinker on the outside
2nd gen have the CCFL bar across the top
3rd gen have the halos set front and back more then the others and the 3 LEDs are at the bottom i believe
Old Jan 15, 2009 | 06:50 PM
AdamJay's Avatar
cool beans in that case i was looking at 1st gen projectors...trying to find some cheap on ebay...i tinted my headlamps to dark and its killing a lot of my light...i have less light with the hids then i did when it was stock..and thats sad
but thanks!
and you said gen 1 and 3 need wired....do they just need wired to a switch for the halos?
Old Jan 15, 2009 | 07:03 PM
Tank07's Avatar
but thanks!
nah u wire them into the parking lights..........that way you can role around with the halos and leds on only and that looks sick
search the how to section
Old Jan 16, 2009 | 06:03 AM
rrauter's Avatar
yeah its one wire that you splice into you parking lights haha
its actually ridiculously easy
i have gen 1 and love them... specially with the hids
Old Jan 16, 2009 | 10:46 AM
liljone's Avatar
CCFL + gen1=sex
there a how to on here how to convert your gen1 to CCFL but I'm a noob i'm not going risk ******* up my projectors.
Old Jan 17, 2009 | 05:33 AM
rrauter's Avatar
haha thats my plan for this coming spring... emp got me hooked when i saw his done and from then i knew i had to do it haha!
i'll let you know how it goes
Old Jan 17, 2009 | 06:44 AM
hailcesar75's Avatar
I don't know if anyone answered your question about the two "eyes" but one is the low beam and the second is the high beam. If your gonna get projectors then you should get two hid kits. I think the h1 would be for the low beam and the high beam is h7 I think (for gen 2) or else you gonna have two beams with the same light output. Someone correct me if I'm wrong. LOL
Old Jan 17, 2009 | 12:37 PM
Topexx's Avatar
I believe Gen 1 and Gen 3 (BOTH) projectors use Hi's/Low's are H1 bulbs. Gen 2 Hi's/Low's are H7 bulbs. The Hi/low (9007 Stock Cobalt light is now split into 2 lights, I'm assuming these are the "eyes" you mean.)
The point of the projector is to "Cut off" glare on your low beam,( this avoids blinding oncoming traffic!); The high beam is to illuminate more, therefore there is no cut off, usually having HID low beams your need for HI beams is lessened so HID Hi's would be more visual then it would be Cost effective. For me, when I get my projectors I will be using Silverstar Hi's, because $50 for something I rarely use is better then $130+...
My $0.02
This is also an excellent forum, might help with future questions:
https://www.cobaltss.net/forums/appearance-48/hids-what-you-should-know-before-you-buy-94774/
Old Jan 17, 2009 | 08:29 PM
Gen 2 are deffinitely 2 different bulbs. I have luminics on both and 1 is h1 and h7. My buddy has a set of hids for $60 shipped and they're fine. I would never pay over $100 for em.
Old Jan 17, 2009 | 11:56 PM
Topexx's Avatar
That's the first time I've seen anyone say anything about Gen 2 having different bulbs, Maybe I just cant read? (Btw thanks for the heads up on gen 2's!)
This is what I was going by... https://www.cobaltss.net/forums/appearance-48/cobalt-replacement-bulb-numbers-95694/
Edit: Also seen this, Must of missed that,
Originally Posted by steddy2112
H7 in the lows there boss and H1 in the highs.
Oh yeah.. I'm Canadian so I get to tack on an extra $15 for shipping + Duty(If its not made in the USA) and minimum ($20) for brokerage fees, Oh yeah, gotta love the extras
Old Jan 18, 2009 | 11:32 AM
What I actually did was look at the base of the bulb and right there it says if it's h1 or h7. That's what i went with before I got the luminics. It probably no big deal having same bulbs for highs and lows but I didn't wanna risk it
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
