Projectors installed quick question tho?
Old Sep 5, 2010 | 01:41 PM
lilhomieb07's Avatar
So me and my buddy have same projector kits installed. The morminto mini H1's. I had to buy the 9007 harness kit so they would work with the stock harness. Well only problem is the high beams dont work. The projectors have a high beam connector that connects to the ballasts. They use the same H1 bulbs but use a shield inside to flip up the light when u use the high beams. Well right when u plug the connector in the shield flips up and then u have no low beams.
Someone was saying you have to swap the wires on the stock harness on both sides for them to work. Which would be orange, pink and red wires on the stock 9007 harness. But idk what ones to swap. Cuz theres 3, low, high and low power wires and i need to swap them in order for the high beam to work.
Anybody had to do this with there kits. I had to leave the high beam connector unplugged on both projectors so i can have my low beams for now which is finw cuz thats what i drive with but it would be nice to use the high beams since the H1 bulbs would be used as well just getting flipped up from inside the projector to aim the light up for the highs. Thanks an hope i get some info.
Old Sep 5, 2010 | 11:00 PM
deuce's Avatar
go to the retrofit sticky and post, i know a few people have these...
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
Bohb
Sep 27, 2015 09:11 PM
