Putting rear bowtie back on!!
Old Mar 27, 2008 | 11:31 PM
EceSSiveMod's Avatar
Dude......ive been looking every and i cannot find a thread or a post on how to get the rear bowtie back on after you paint it.....what do you use.....and how do you put it in the exact same place without putting it crooked etc.....thanks in advance
anyone haha
Last edited by EceSSiveMod; Mar 27, 2008 at 11:31 PM. Reason: Automerged Doublepost
SSSCEnthusiast's Avatar
Just pick up a tube of trim adhesive from napa/advance/autozone/walmart
Old Mar 27, 2008 | 11:33 PM
to make sure i put it in the exact same spot?
dman090's Avatar
ya and u should be able to still see the outline of where it used to be n e ways
Old Mar 27, 2008 | 11:34 PM
pimpnwink's Avatar
double sided tape. and a chalk line. And a level. Maybe a laser
should i use the double side 3M tape or super glue??
Old Mar 27, 2008 | 11:35 PM
CinciSS07's Avatar
tape, dont super glue it. bad idea
Old Mar 27, 2008 | 11:36 PM
Red07SSNA's Avatar
Get some automotive tape, a level, and then measure the location of an emblem on another Cobalt. Park your Cobalt on a level surface. Run/fix the tap across the trunk lid at the lowest point of the emblem's position and use the level to insure the tape is straight/level across. Then measure and mark the center of the tape on the trunk lid. Then using 2 strips of tape to mark the outer sides fix the tape to where the left and right side of the emblem will be -- use the level again to make sure they are straight up. Now you have the area the emblem goes marked out with the tape and can use the tape to help guide you.
that help?
Old Mar 27, 2008 | 11:38 PM
does that stuff hold good thru winter. car washes etc....
that help?
very much so thank u
Last edited by EceSSiveMod; Mar 27, 2008 at 11:38 PM. Reason: Automerged Doublepost
Red07SSNA's Avatar
Spend a few bucks for a new emblem to make sure it stays.....
tomj77
Oct 2, 2020 05:36 PM
Tupp
Sep 29, 2015 11:07 PM
Cptnslo
Sep 24, 2015 09:32 AM
Joe09
Sep 18, 2015 09:22 AM
QuickSilver_SS
Sep 17, 2015 05:38 PM
