Question about headlights....
Old Feb 12, 2009 | 01:29 PM
BlackSSNick's Avatar
So I have 1st Gen projectors with 8000k HID's in them. But I am not happy with them because the halos and leds keep being weird on me, so I want to get a pair of black housing stock cobalt headlights from ebay.
My question is (No flaming, yes I know)
What would I have to do to swap my HID kit over to the stock cobalt headlights, I know I'd have to buy the right HID bulb for the headlight type...but if I want low/high beams with these would I have to buy a new harness?
Again no flaming, I know HID's in reflector housings make people mad, so you don't have to tell me.
bump again
Last edited by BlackSSNick; Feb 12, 2009 at 01:29 PM. Reason: Automerged Doublepost
Old Feb 12, 2009 | 01:32 PM
FASTL61's Avatar
they wont work since your projectors are h1 and stockers are 9007.new hids need to be ordered in the 9007 form
Old Feb 12, 2009 | 01:35 PM
MachiBLue's Avatar
besides buying the correct bulb for the stockers, I don't think you'll have to buy an new harness for the lo/hi. I think with normal HIDs you lose the high beams, on the stockers. If you want a lo/hi beam I think you will have to purchase a bi-xenon kit, or maybe just the bulbs? I'm not sure on that one, but its a start
Old Feb 12, 2009 | 01:43 PM
NS06G5's Avatar
if it's a 2 stage bulb you should get both settings?
Old Feb 12, 2009 | 08:40 PM
well the bulbs that are in there now won't work, but it's a 9007 harness with H1 bulbs from 3B spec. I don;t think i'll need a new harness unless I want to go high low, but I might just keep the low beam only. I rarely use high beams anyway since HID's are so bright. All I should have to change is the bulb and the headlight obviously.
Old Feb 12, 2009 | 10:56 PM
cobalt man's Avatar
i wouldnt bother with it bud because there is hardly any difference in the high and low beam
Old Feb 12, 2009 | 11:15 PM
Switt23's Avatar
The only difference in the bi-xenon bulb kit's it the location of the bulb it self. Same bulb, it just moves forward or back in the housing.
I would recommend a set of projector housings, but I am biased. I have had mine since Oct. 2007 and would never go back.
However to answer your question, all you need is the new HID kit to fit the 9007.
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
