Quick question to those running HID's and DRL's
Old Apr 2, 2010 | 09:38 AM
SI FTL's Avatar
My Cobra came with 8K HID's when I bought it. After driving the Cobalt around so much at night, I miss the effect and lighting. My question is:
Do I need the 10.00$ DRL module?
I am seeing mixed things about this, But I am guessing in order for my DRL's to work, I have to buy the module?
I am ordering from 3B Spec, 10k with PnP wiring harness, and 35W digital Ballast..
Quick hand, please? Thank you.
Old Apr 2, 2010 | 09:41 AM
BlackARCA06's Avatar
If your a 07 and up just pull your DRL fuse. you'll have to just turn your lights on by yourself though.
Old Apr 2, 2010 | 09:43 AM
SI FTL's Avatar
My car is a 2008. So, in which way you're going; Pull the fuse and do not get the DRL module?
If I want to keep the DRL, I have to buy the module though, correct?
Sorry if I'm being a bit ignorant.
Old Apr 2, 2010 | 09:45 AM
Yea you can pull your DRL fuse in the fuse box under the hood. Ive never heard of this module so hopefully someone can give you a solid answer. But I have a 06 so I dont have DRL's, but if I did I would just pull the fuse.
Old Apr 2, 2010 | 09:47 AM
SI FTL's Avatar
Thank you for the suggestion, I as well hope to get some input on this. I know HID's do not like to run on anything less than full power, so this Module makes me wonder. It's only 10 dollars, So I can't imagine it would hurt!
Old Apr 2, 2010 | 09:50 AM
Yea, thats cheap I would maybe consider getting it.
Old Apr 2, 2010 | 10:05 AM
riko540's Avatar
I have the DRL module and the issue I had was the DRL fuse kept blowing. I couldn't figure out why so I just pulled the fuse. The lights still come on automatically when its dark, but if there is too much light the headlights will stay off.
Old Apr 2, 2010 | 11:54 AM
TommyP's Avatar
AWD > FWD
Ya the DRL module really doesn't work that well. also get a relay harness so that your hids take power directly from the battery so you don't burn out your stock wiring.
Old Apr 2, 2010 | 12:01 PM
bmaynard06's Avatar
I agree. I read a lot about the DRL module and people said they didnt work well so I just ended up pulling the fuse. Works like a charm!
Old Apr 3, 2010 | 10:57 AM
06CSS's Avatar
I have gen 3 lights and I still got DRLs (in three diff. ways they can be on), I had my lights pro-installed, though. Not sure how they were done.
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Bohb
Sep 27, 2015 09:11 PM
