raptor H.I.D. kit!!
Old Apr 26, 2010 | 10:45 AM
seandooley's Avatar
raptor H.I.D. kit!!
OK so I got the kit and they dont work on my headlights
I need to know were the white red and black wires connect from the harnes to the headlight. The headlight has pink orange and black im guessing the black goes to black so were do the other two go?
the red is the high beams and the white is the low beams
So again if anyone can tell me what the pink and the orange wires are ill be able to hook them up.
thanks.
Old Apr 26, 2010 | 10:48 AM
BLAZIN07SS's Avatar
I'm too JDM for you
it should be a plug and play kit. you got the 9007 kit right?
Old Apr 26, 2010 | 10:50 AM
iboost's Avatar
pics of the harness?
Old Apr 26, 2010 | 10:54 AM
CudaJoe's Avatar
you might not be matching the wiring correctly if everything is plugged in but the headlights dont come on. try flipping the plug that goes into the ballast from the bulb upside down and see if they come on then.
Also make sure you are using the 9007 hi/low HID kit.
Old Apr 26, 2010 | 01:09 PM
seandooley's Avatar
Yup i have the 9007 hi/low kit.
I have not tried the rverse polarity thing yet with the ballasts
The main issue is the blue connector that connects to the old lights....i dont have pictures so ill try to describe it everyone has this blue female conector that connects to the back of the old bulb. the connector has three wires orange pink and black....
the raptor kit gives you a male blue connector with no wires in it, I have to manually plug in the red, white and black wires so that when it connects to the female connector they match up...i know the two black ones go together
I dont know what the orange and pink ones go to.
I would realy appreciate if someone who has the kit on their headlights could tell me
I have the same kit on my fogs but didnt need the harness it was just plug and play.
Old Apr 26, 2010 | 01:40 PM
wantedSS/TC's Avatar
reverse the connectors. guaranteed it will work.
Old Apr 26, 2010 | 01:49 PM
09turbo's Avatar
stock headlights?
Old Apr 26, 2010 | 02:03 PM
iboost's Avatar
this^
Old Apr 26, 2010 | 02:07 PM
08slatecobalt's Avatar
I believe what he is trying to say is that the wires need to be put into the blue 9007 connector...so he is wanting to know which one goes where in the connector
Old Apr 26, 2010 | 02:29 PM
it's like the triangle, square and circle pieces that go into the wood template with the same exact shapes.
you can't force a circle through a triangle template
Old Apr 26, 2010 | 04:13 PM
seandooley's Avatar
yes stock headlights....
i just didnt want to blow anything...so didnt want to switch wires back and fourth
i guess i will just guess what wire goes were then switch them around and if that dont work do the reverse polarity thing.....
thanks for all the suggestions ill try and get some pics of what it looks like all done got blacked out stock housings with 3000k 35 watt ballast....on fogs and headlights
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
