Removing Nightshades Tint
Old Dec 30, 2007 | 11:38 PM
osh!thandle's Avatar
Anyone got an idea how to remove nightshades spray tint from taillights? i decided to go a different route with em an i'd like to avoid buyin a new set ($100 was the cheapest i could find). I'm not sure if paint thinner is the way to go. thanks for any help.
Old Dec 30, 2007 | 11:40 PM
Jared B's Avatar
i wouldnt u paint thinner
Old Dec 30, 2007 | 11:41 PM
madmark's Avatar
any paint remover will work, brake cleaner works also
Old Dec 30, 2007 | 11:42 PM
DSMissed's Avatar
why don't you just trade with someone that wants tinted tails
Old Dec 30, 2007 | 11:44 PM
cool thanks for the info. just wasn't sure enough to go ahead
Old Dec 31, 2007 | 01:02 AM
07blackg5's Avatar
Slobodan Milošević
i heard laquor(sp?) thinner will take it off
Old Dec 31, 2007 | 01:53 AM
bikeboyben14's Avatar
and as well if u got some elbow grease.. wetsand with 800 and reclear them
Old Dec 31, 2007 | 01:54 AM
Coblt ss super's Avatar
i used Nightshades on my headlights at one point, and didnt like it, i used Paint thinner and it took it off, made sure it wasnt melting the plastic so i did a little spot and took it off right away.
Old Jan 1, 2008 | 07:29 PM
11secSRT4's Avatar
Beware of spraying brake clean on plastics.
Old Jan 1, 2008 | 07:32 PM
outtamymind's Avatar
ya thinner and brake clean and plastic do not mix.
Old Jan 1, 2008 | 07:40 PM
hawlyns711's Avatar
^^laquor thinner or paint thinner?
Old Jan 2, 2008 | 08:08 AM
paint thinner
Old Jan 3, 2008 | 03:52 PM
J 1 Avs's Avatar
can i see pics of your tailights...
because i would trade you for non tinted ones if i like them
Old Jan 3, 2008 | 03:59 PM
chevysalesman614's Avatar
paint thinner, as well as nail polish remover would work. pretty much anything with acetone in it. good luck, and make sure they're dry before the re-install, god knows you'd cry if it dripped on your bumper.
^this is probably the best option, at least the easiest.
laquer thinner does not work on modern day paint, and in my opinion probably wouldnt work on nightshade.. it might, but i doubt it.
Last edited by chevysalesman614; Jan 3, 2008 at 03:59 PM. Reason: Automerged Doublepost
Old Jan 3, 2008 | 04:01 PM
campo165's Avatar
took mine off with ease...and tha was with about 4 coats of nightshades and 3 coats of clear
Old Jan 3, 2008 | 04:04 PM
thats why i said i wasnt sure, apparently i stand corrected. buy whatever is cheaper.
dman090's Avatar
I went to home depot, bought some lacquer thinner and applied it to the tinted brake lights with a rag and the tint came off easily.
Old Jan 3, 2008 | 06:11 PM
Area47's Avatar
Rent me! per hour
call vht direct and ask them
do NOT use any type of thinner, or brake cleaner.
also, don't use 800 grit paper unless you like having sand marks in your lights.
dieGone
Sep 23, 2015 10:20 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
