Replacing Shift knob Question
Yes, I know there are other posts that discuss this, but I couldn't find one that answers the specific questions that I have. I will deleate this when I am done if that helps. That being said;
I want to replace the shift knob. I know that I need a knob that has set screws to hold the shifter knob on sense the shaft is not threaded. (Right?) But how do I get the boot to stay up by the knob? I do NOT have the reverse lock out to hold it up there either. Thanks guys!
On the 2008 ss/tc, theres a zip tie that goes through a loop inside the boot. You tighten it around the collar right below the lockout mechanism. I know you don't have a ss/tc but maybe its a ziptie. If you pull the boot up over the knob, u might see a part of the ziptie.
oh well as far as getting another on there i dunno. I have a short shifter with the stock boot and the boot doesnt attach at all. If you figure something out let me know.. Cause ive been searching for a solution myself
NON of you guys have answered the OP's question. Which was,is there a replacement knob he can install if he removes the stock knob. And then reattach the boot.
And to answer his question, non that I know of. The knob would have to be able to work with the reverse lock out, and then have some sort of set screw from the side to keep the knob in place. So again to answer the OP since no one else seem to know how to read, NO. Not to my knowledge.
yes...your only direct replacement option is the 2.4 shift *** with the silver top instead of black, i have done this.
Other then that you can glue or make your own threads to thread one on or get a short throw that has threads....or set screws
/thread
ya, I actually was asking how to keep the boot up by the knob, not if there is a knob that will work. I know how to get a knob to work, it must have set screws to hold it in place. Zip tie idea should work though thanks!
Haha. I find it funny that the one claiming everyone else couldn't read was himself the one who could not read.
Pro tip # 645:
put the question first then the extra bs and explanation
most people dont read it all...so if you want the help then you need to make it more clear what you are asking for
that and the actual trhead title is about replacing the shift knob not the boot....
thread title in relation to actuall question = fail
Last edited by NWAE Cobalt; Oct 31, 2008 at 08:45 PM. Reason: Automerged Doublepost
my question was pertaining to replacing the shift knob, I am not planning on changing the boot. If I replace the knob, how do i keep the STOCK boot up near the replaced KNOB. So I don't know why you say the title was not accurate.
