Replacing Shift knob Question
Old Oct 30, 2008 | 04:54 AM
cjlee07's Avatar
Question Replacing Shift knob Question
Yes, I know there are other posts that discuss this, but I couldn't find one that answers the specific questions that I have. I will deleate this when I am done if that helps. That being said;
I want to replace the shift knob. I know that I need a knob that has set screws to hold the shifter knob on sense the shaft is not threaded. (Right?) But how do I get the boot to stay up by the knob? I do NOT have the reverse lock out to hold it up there either. Thanks guys!
Old Oct 30, 2008 | 03:53 PM
cjlee07's Avatar
bump for a hint? ha. The searches I do only tell me what to do if I have a reverse lockout.
Old Oct 30, 2008 | 03:54 PM
alleycat58's Avatar
I thought the 2.2/2.4 knob was threaded. Like 95% sure that's the case.
Old Oct 30, 2008 | 03:56 PM
bshep20's Avatar
no its not, the boot attaches to the bottom of the knob. you twist the boot ring at the base of the knob and slide the knob off. It comes straight off.
Old Oct 30, 2008 | 04:05 PM
cjlee07's Avatar
i got that part, I even got down how to remove the boot.... But how to keep it up around the knob?
Old Oct 30, 2008 | 04:24 PM
nutsandboldts05's Avatar
The knobs on these cars are junk. I should replace mine too... What did you replace yours with?
Old Oct 30, 2008 | 06:22 PM
silver06cobalt's Avatar
you have to pry each individual piece that grabs the shifter itself off all at the same time.. then just pull on it really hard. Thats what i did
Old Oct 31, 2008 | 05:57 AM
cjlee07's Avatar
I can get the old shifter off, but how to make the new one stay on and keep the boot up to it is the question.
Old Oct 31, 2008 | 10:12 AM
hiltu's Avatar
On the 2008 ss/tc, theres a zip tie that goes through a loop inside the boot. You tighten it around the collar right below the lockout mechanism. I know you don't have a ss/tc but maybe its a ziptie. If you pull the boot up over the knob, u might see a part of the ziptie.
Old Oct 31, 2008 | 10:23 AM
oh well as far as getting another on there i dunno. I have a short shifter with the stock boot and the boot doesnt attach at all. If you figure something out let me know.. Cause ive been searching for a solution myself
Old Oct 31, 2008 | 11:54 AM
chevy cobalt 08's Avatar
there's a plastic piece on the stock shift boot it attaches to, use that.
Old Oct 31, 2008 | 03:05 PM
Blue_Balt's Avatar
What knob can you put on after you take the stock one off?
Old Oct 31, 2008 | 05:36 PM
that piece isnt going to do any good on an aftermarket knob.
You are more than likely going to have to buy a new boot as well
Old Oct 31, 2008 | 07:33 PM
R4race's Avatar
you need to make some type of collar for the boot to sit into or above
if you can weld, maybe tack on a washer
Old Oct 31, 2008 | 07:40 PM
chillfactor's Avatar
flip the boot upside down while on the shifter put a zip tie on the shifter its self were u want the boot to stay and then fold the boot back down and install the knob
Old Oct 31, 2008 | 07:47 PM
NWAE Cobalt's Avatar
just us a tap and make your own threads
Old Oct 31, 2008 | 07:49 PM
06SS/SC STAGE2's Avatar
NON of you guys have answered the OP's question. Which was,is there a replacement knob he can install if he removes the stock knob. And then reattach the boot.
And to answer his question, non that I know of. The knob would have to be able to work with the reverse lock out, and then have some sort of set screw from the side to keep the knob in place. So again to answer the OP since no one else seem to know how to read, NO. Not to my knowledge.
Old Oct 31, 2008 | 07:53 PM
XM15's Avatar
Thats the way.
Hmmmm.....
Old Oct 31, 2008 | 07:57 PM
no reverse lockout on the ls (read sig)
yes...your only direct replacement option is the 2.4 shift *** with the silver top instead of black, i have done this.
Other then that you can glue or make your own threads to thread one on or get a short throw that has threads....or set screws
/thread
Old Oct 31, 2008 | 07:59 PM
cjlee07's Avatar
ya, I actually was asking how to keep the boot up by the knob, not if there is a knob that will work. I know how to get a knob to work, it must have set screws to hold it in place. Zip tie idea should work though thanks!
Haha. I find it funny that the one claiming everyone else couldn't read was himself the one who could not read.
Old Oct 31, 2008 | 08:03 PM
XM15's Avatar
lol someone caught it.
Good luck with the project.
Old Oct 31, 2008 | 08:39 PM
outtamymind's Avatar
hmm if it works let me know cuz i had the same thought, just been to lazy and busy to actually try and figure it out. but i really really want to put a differen't shift knob on.
Old Oct 31, 2008 | 08:45 PM
thats how it is held on the the first place, of course it will work!
right...your first question in the thread was about the shifter itself
Pro tip # 645:
put the question first then the extra bs and explanation
most people dont read it all...so if you want the help then you need to make it more clear what you are asking for
that and the actual trhead title is about replacing the shift knob not the boot....
thread title in relation to actuall question = fail
Last edited by NWAE Cobalt; Oct 31, 2008 at 08:45 PM. Reason: Automerged Doublepost
Old Oct 31, 2008 | 10:31 PM
I read it fine, you question was pertaining to the knob and not the boot, anyhow good luck and and find a real mod to invest in other than a boot.
Old Nov 1, 2008 | 02:27 AM
cjlee07's Avatar
my question was pertaining to replacing the shift knob, I am not planning on changing the boot. If I replace the knob, how do i keep the STOCK boot up near the replaced KNOB. So I don't know why you say the title was not accurate.
