Retrofit Info plz
Old Jan 3, 2011 | 09:47 PM
SilverSS_TNR's Avatar
Retrofit Info plz
so im thinking of getting my stockers retrofitted, i currently have ebay projectors, and for obvious reasons id like to upgrade, the cutoff line on my is horrible, they go out everytime i hit a bump or when it rains, just plain bad, buuuuut idk like some pros/cons on the retrofit to see if its worth the money, or if i should just paint my stockers myself and just put an HID in it
info plzzzzz and thankksss
Old Jan 3, 2011 | 09:49 PM
N1ckateen's Avatar
I made my retrofits with the kit from buyhids.com and they're pretty badass. light output is amazing, but i've never had my highbeams from the start. I know i wired them up correctly too, but still even the low beams with HID fogs as well really does the job. Seems like most people on here get some projectors from like an acura TL or something and they are even better.
Old Jan 3, 2011 | 09:55 PM
TommyP's Avatar
AWD > FWD
Cons, cost.
Pros- more light, sharp cutoff, colorful cutoff, reliability, looks.
Easily worth the money.
Old Jan 3, 2011 | 09:57 PM
TommyP's Avatar
AWD > FWD
TLs are going to be the most expensive setup you can buy, but is also the best projector, and is also the most difficult to install. They're what I'm getting, you can't get better bixenon projectors at the moment. Mini H1s and FX-Rs are what most people use, and are very easy to install, especially the mini H1s.
Old Jan 3, 2011 | 09:58 PM
Originally Posted by TommypSS/TC
Cons, cost.
yeah i was leaning towards retros, after seeing you sig a while back, i was like damn those looook good, im proly gunna send my stockers to buyhids.com and have them paint and retrofit, since they are perfect no scratches or anything, save me some moneys,
Old Jan 4, 2011 | 11:26 AM
cubaniche's Avatar
I just got the retros from buyhids with 6k bi-xenon. Love them so far. Sorry for the crappy pics:
This was the full kit already installed. I didnt have to do anything except for mount and wire them on the car. Only thing I didnt like is that the projector is held in the housing by these plastic prongs that a bolt snaps into. They pop out pretty easily and you end up with a loose projector bouncing around in the housing. So, with the help of a friend, we put hot glue in the prong with the bolt and it is holding like conrete lol Nice product though!
Old Jan 4, 2011 | 01:44 PM
ayellaone's Avatar
how much did they cost and did you send them your stock lights?
Old Jan 4, 2011 | 02:07 PM
2.2balt's Avatar
You have to swap the white and blue wires (IIRC) on BOTH of the hid harness blue connectors. I thought mine were screwed too then buddy told me to do that and I only tried it on one side and they'd turn on but not off so I gave up again. Then I had time and I did both sides and it works mint. Its so worth it too. Bright as f**k!
They're phone pictures so yeah they suck. They're 6k with white halos. Very easy install and very easy HID kit to wire up. Just follow the instructions.
Does anyone know what the halos are rated at in terms of hours? I'm debating wiring them to my parking lights but I don't want them to die super fast lol.
Old Jan 4, 2011 | 03:19 PM
cubaniche's Avatar
Their whole kit installed in new housings and bulbs I think is 399+shipping.
Old Jan 4, 2011 | 08:37 PM
to have your stockers sent in and painted its 249, which i feel is a decent deal, the HID kit alone is about 100 dollars, the projector kit is proly another 100-150, painting materials is about 30-50 and then all the labor, and great ending product, got my vote...
Old Jan 4, 2011 | 08:54 PM
arman14's Avatar
As TommypSS/TC said the TL is the best projector, performs even better with ZKW-R lenses.
I wanted to retrofit a set of those on my cobalt but I screwed up 2 sets of headlights
The projector is too big and I just couldn't make it fit on the stock reflector.
I ended up with a set of FX-Rs and later on the road with a set of Mini D2S Morimotos. The minis are very easy to work with and they performed better than I expected, I recommend these projectors to anyone working on a low budget.
Here's a link to my retro build
https://www.cobaltss.net/forums/elec...-retro-223895/
Old Jan 4, 2011 | 08:59 PM
yesss i remember following your build, and they turned out pretty damn badass, but im not skilled enough or proly dont have the patience to try and build my own, or the tools/equipment lol but yes those are good lights.
Old Jan 4, 2011 | 09:04 PM
thedude411's Avatar
E55 projectors r also nice. I'm not a fan of the shrouds that buyhids uses. Ugly IMO.
Old Jan 4, 2011 | 09:09 PM
arman14's Avatar
Thanks man
Is not hard to build them and they really worth it, That was my second set actually.
Old Jan 4, 2011 | 10:26 PM
TommyP's Avatar
AWD > FWD
ya the TLs take a lot of work to make them fit, but they will, I've seen it done several times. If you order the TLs from TRS, they come with ZKW-R lenses pre installed, which is what I probably will do if I don't buy them used to save money. The FX-Rs are a great choice for getting the best bang for your buck, ease of install, and good quality.
Old Jan 4, 2011 | 10:33 PM
balt21's Avatar
Whatever you do, just please don't put HID's in the stock reflector housings.
retro's ftw!
Old Jan 4, 2011 | 10:41 PM
hey where did you get your retros from? buyhids.com?
Old Jan 4, 2011 | 10:48 PM
TommyP's Avatar
AWD > FWD
Yes that's where they're from.
Old Jan 4, 2011 | 10:51 PM
arman14's Avatar
TRS FTW
Some guy here has a set of TLs but I think he built a custom bracket.
Old Jan 4, 2011 | 10:53 PM
TommyP's Avatar
AWD > FWD
It's worth a shot either way, if I have to make a custom bracket then so be it, if I get tired of trying I'll sell the TLs and use FX-Rs, but I'd rather have the TLs if I can.
Old Jan 4, 2011 | 10:56 PM
arman14's Avatar
Tl>fx-r
Old Jan 4, 2011 | 10:59 PM
2.2balt's Avatar
Heres a slightly better pic of mine I took today...again with my phone lol
These projectors aren't bad. They're a little big though, and the shrouds aren't the nicest around, but for a no cutting required install they're fine.
And +1 for the no HIDs in stock lights. Projectors are wayyyy better.
Old Jan 4, 2011 | 11:16 PM
i saw a picture you posted in "SHOW YOUR HIDS" thread and you have two lights on each housing on, is that a pic of your hi beams on?
Old Jan 4, 2011 | 11:27 PM
bacardi's Avatar
The kit buyhids.com uses is a cheap kit you can find on eBay or many of the Chinese wholesale websites around the internet...might as well buy the mini H1 projectors that TRS sells, same principle as far as mounting, but much better quality/cutoff/width.
I'm sure you can pick up CCFL rings off of eBay in a variety of colors...you'll want to use 70mm rings with the MH1 projectors. You can also paint the housing black or any color you like (match your car, or something) while the lamps are taken apart for the retro.
Old Jan 5, 2011 | 12:37 AM
KyleGyger's Avatar
wow. did u have to send your lights or you paid 400 and they sent you new headlights retrofitted?
