Should I? (Door Trim)
So i'm thinking about taking the external door trim for my LT cobalt, now I really like the way the SS's look so it's not a matter of if i'd like it or not it's more a matter of will the paint under the trim will be darker then the rest of the paint due to sun light. I have a silver cobalt and it's about 2 years old if that matters. Thanks!
I have a summit white LS. I took mine off an imediately noticed if I was with 2 feet I could see a color difference. It was yellow =\
That was a few months ago, couple washes ago and some time, I cant really see it anymore unless im close enough to eat off it.
EDIT: I defintly say go for it! Looks good
I have an orange balt and I took it off after two years and there was NO difference at all.
Ummmm why????
Use some detail spray and that's really all that is needed
Ummmm why????
Of course make sure you wax it right after you get it off and cleaned up!
I used that "Orange" degreaser and DO NOT use it. I have to re-clear my trunk (removed bow tie). Not a huge problem for me because I was planning on welding the trunk key hole closed anyway. But if you dont want to risk it, stay away from thoes types of products.
Damn, so is the verdict no on goo gone because it'll take the clear coat off or am i misreading. Anyway, i'll pick up some stuff tomorrow to take this stuff off. Any other tips would be awesome, thanks!
Ive used goo gone on every inch of my car where something had to come off. Put a little on a cloth, rub it it clean. then use a wet cloth with some water on it to clean any goo gone that may have stayed. and then i used meguiars detail spray and sprayed it. No problems... no issues
Delta coupe
Sep 30, 2015 08:11 AM
