SS side skirts question
Old Feb 19, 2014 | 02:08 PM
G5_Stuntin's Avatar
Are the SS side skirts interchangeable or do you have to mount the RH to the right and the LH to the left?
Old Feb 19, 2014 | 02:32 PM
KMO43's Avatar
I just took a quick look at mine jacking point arrow is on the back mounting holes are different on the ends other than that they look symetric but I didn't measure them
Old Feb 19, 2014 | 04:08 PM
andrewcarr1993's Avatar
Different
Old Feb 19, 2014 | 04:21 PM
G5_Stuntin's Avatar
But if they are symmetrical what prevents you from mounting the passenger side onto the driver side and vice versa?
Old Feb 19, 2014 | 04:24 PM
BlackielawlessSS's Avatar
Yes they are different.
Old Feb 19, 2014 | 04:33 PM
C_A_D88's Avatar
There the same but the mounting tabs won't line up on the other side
Old Feb 19, 2014 | 09:42 PM
G5_Stuntin's Avatar
Well correct me if I'm wrong but I thought you had to drill the holes your self to mount it.
Old Feb 19, 2014 | 10:47 PM
Only if non SS, although you can mount it with strong tape too.
Old Feb 20, 2014 | 01:18 AM
xxenjoi11's Avatar
i need a diagram of those holes so i can drill, thats all im waiting on.
Old Feb 20, 2014 | 08:45 AM
G5_Stuntin's Avatar
So if I drilled the holes I could mount a passenger side panel onto the driver side or does that still not work? As far as strong tape goes, what have people had success using?
Old Feb 20, 2014 | 09:42 PM
G5_Stuntin's Avatar
Old Feb 20, 2014 | 09:44 PM
xxenjoi11's Avatar
the sides are not interchangeable, the way they're formed it doesn't line up I don't think
Old Feb 20, 2014 | 09:48 PM
The best outdoor double sided tape 3M makes, not cheap but should hold.
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
