SS/TC Grill
Well I like the stock grille because I'm all about keeping a 100% OEM look, and its the one used on the first pic ever released of the cobalt (at least on j-body.org):
Then again, the TC grille appeared on some of the other original concept artwork for the SS, AND it matches the honeycomb pattern on the rear bumper, so its really up to you.
Go for it if thats the look you want.
Yes they are worth it! Look real nice!
I like the fact that they match the SS/NA rear grille too!
https://www.cobaltss.net/forums/appearance-48/08-ss-tc-grille-kit-available-ced-106359/
Cracked the housings open out of the oven. FINE Steel Wool on all the "chrome" material. Cleaned with rubbing alcohol. Krylon Fusion gloss black paint-3 coats. Kylon clearcoat-2 coats. As for the orange side markers, they are just sanded and tinted using VHT niteshades and the same Krylon clearcoat. then reassemble.
