switchback led question
Old Jun 6, 2012 | 12:00 AM
juan1101's Avatar
i dont now if i put this in the right spot ...but i just got some switchback led for my turn signal and when i switch my turn signal on it blinks fast does this mean i connected my resistors wrong?
Old Jun 6, 2012 | 12:03 AM
Sir_Hiro's Avatar
Sounds like it...or they arent big enough ;D
Old Jun 6, 2012 | 12:04 AM
Cobalt08LS's Avatar
ceck to make sure your resistor is hooked up properly
Old Jun 6, 2012 | 12:10 AM
juan1101's Avatar
i was following the how to that mkurkly (<< i think thats his name ) did and the back lights are doing the same thing to blinking fast
Old Jun 6, 2012 | 12:19 AM
Sir_Hiro's Avatar
The back lights will blink fast cuz the comptuer thinks that one of your bulbs is out..so it blinks fast to tell the driver that it is...
If you have a multimeter probe the wires..and see which one has fluctuating voltage...if your resistor is not wired into that then ya...wire it into it..best I can explain I fail at writing up how tos
Old Jun 6, 2012 | 07:20 AM
cobythecobalt's Avatar
I put my resistors in last night and the hyperflash stopped. i hooked it to the blue wire and the black wire on the turn signal harness. polarity doesn't matter, and if you got the resistors with the bulbs, then most likely they're the right ones. ur prob just on the wrong wires
Old Jun 6, 2012 | 07:46 AM
juan1101's Avatar
Well i connected mine to the.blue wire and one of the black ones that goes to the.side marker
Old Jun 6, 2012 | 08:33 AM
there is a black one and a dark brown one that looks like light black. you might have hooked it to that one by accident. i almost did!
Old Jun 6, 2012 | 08:35 AM
juan1101's Avatar
U might be right ima look at it later on today
Old Jun 6, 2012 | 09:08 AM
ya, lets us know how it works
Old Jun 6, 2012 | 09:56 AM
juan1101's Avatar
Will do
Old Jun 6, 2012 | 09:15 PM
juan1101's Avatar
no luck in getting it to work i tried 2 other wires and it still doing the same thing
Old Jun 6, 2012 | 09:42 PM
Sir_Hiro's Avatar
My guess is bad resistors then..
Old Jun 6, 2012 | 09:48 PM
juan1101's Avatar
do you think i can buy one from a store or only online...and does it do anything bad if the resistor are bad
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
