Tail Light Replacement
Old Jul 12, 2006 | 10:08 AM
phuwalt's Avatar
Driving home yesterday, i turned on my right turn signal, and it blinked 3x as fast as normal..
Got home and found that my rear right tail light is out... are these hard to replace? I used the search function but couldnt find anything.
Are there certian types that work best wtih the cobalts??
FYI - 2.4 2door SS
Old Jul 12, 2006 | 10:14 AM
Stealth06LT's Avatar
My girlfriends eclipse had that problem a few weeks ago, you prob need a new bulb, or maybe a fuse, but hers was a bulb. Its cheap and easy to repair.
Old Jul 12, 2006 | 10:27 AM
Dark-Fx's Avatar
New bulb probably. Pull back on the carpeting covering the light housing, twist the center wiring harness (bulb harness) and the bulb will come right out. I've had to replace one of mine already too.
Make sure you're turning it the right way, and make sure you're twisting it so the part that turns is touching the actual lense.
RaginChopsuey
Oct 27, 2015 01:27 PM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
z28addiction
Sep 28, 2015 12:03 AM
