Trim Reinstall
Trim Reinstall
So after painting my trim, (which was exceptionally hard to remove) I re-installed it, and, though everything is fine, the trim above the glove box is a bit looser, and wobbles a little if you push on it. Any way to fix that? Thanks.
Alright, I have to remove it once more anyways to install an aftermarket deck later this spring anyhow, and do just a little touch up (I missed a tiny spot that, though no one will notice, I know it exists) so I'll double check then. I know I have all the clips, but some are probably just a little off. Thanks guys. =)
Delta coupe
Sep 30, 2015 08:11 AM
