Ugly yellow interior lights
Old May 11, 2009 | 12:12 AM
  #76
wardzach2007's Avatar
you can get what ever led count of led's that you wan. 4,6,8,10 LED and so on. Just make sure it fits in the light cover or the area you are installing
Old May 11, 2009 | 12:17 AM
  #77
stretch89's Avatar
That's what I mean I don't want to have fitment issue so what led count is safest? I don't hbe a clear answer reading through the thread
Old May 11, 2009 | 12:31 AM
  #78
If you go around 4-6 you should be safe. Take for instance the rear view map lights. It has the plastic cover to cover it. You can't have something packed with LED's to where it's to round where you can't snap the plastic cover back on.
Old May 11, 2009 | 12:57 AM
  #79
codytheoutlaw's Avatar
Originally Posted by codytheoutlaw
i bought the 12. it wont fit in the reverse light socket. i might hit the bulb with the drimmel and make it fit.
when i put the bulbs in the 3rd brake light, they stay lit a little. is there a resistor i can put in there to make it stop?
its funny someone bumped this thread, because i finally got around to installing my lights today. to make the 12 led bulbs work, i cut the light socket off at the top of the raised dot. i sanded the rough edge off and they looks stock.
to fix the 3rd brake light, i went to autozone and bought some led load stabilizers and wired them in. so now they aren't lit all the time, and my cruise control should work. i haven tested it yet.
Old May 12, 2009 | 06:28 AM
  #80
stretch89's Avatar
JUST ordered! cant wait to get my leds i read that they do fast shipping
Old May 12, 2009 | 08:54 AM
  #81
^Yeah, I live in Texas and they do fast shipping for such a small product.
Old May 15, 2009 | 12:40 AM
  #82
stretch89's Avatar
yup just got em today a total of 2 day shipping wow i recommend them they look dope!
Old May 16, 2009 | 07:39 PM
  #83
blink30056's Avatar
anyone having problems with the lights not going completely off-- look at my post in problems and service-- dont understand why this is happening and im afraid its going to drain my batt
Old May 17, 2009 | 07:17 PM
  #84
stretch89's Avatar
they are leds read post theirs ways to have them completely off i think its called a resistor i aint 100% sure but the leds lit lightly wont kill the battery
Old May 17, 2009 | 11:41 PM
  #85
All LEDS do this. That's what a LED does.
These LEDS will never drain your car out. It would take alot, and I mean ALOT of LEDS to drain your battery.
Plus they turn off when the power source shuts off. So you should have no problem.
Old May 18, 2009 | 12:10 AM
  #86
stretch89's Avatar
agree
Old May 30, 2009 | 07:07 PM
  #87
007CobaltLS's Avatar
OK, I'm going to bump the thread because I want to order LED's for my 07 LS sedan, but I want to make sure the ones I get will work.
The lights I want to replace are as follows:
Front side marker (194) [in headlight behind reflector it looks like?]
Rear side marker (194) [in taillight]
License plate (194)
Dome light (festoon) [all I have is the festoon bulb...don't have the 194's in there]
Reverse lights (921)
Third brake light (912) [what bulb corresponds to this one?]
So I need 6, 194 bulbs...should I get them color matched to the lens? Or should I get cool white for all of them? I need 2 921 bulbs in cool white. I also need the festoon bulb. Lastly, I need some bulbs for the three in the third brake light....what do I use there...is that a 921 also?
I'm going to go to V-LEDS.com and SBL.com and see what I find, I'll edit this with some bulbs and I'd like some feedback if those are correct or what I should use instead.
Thanks.
Here's what I came up with for bulbs...let me know if I should change anything. I wasn't sure about diameter for the bulbs, so I chose some that are 12 LED, but perhaps they won't fit. They are .6" diameter (that doesn't seem too big).
1 RL4410-xHP9 Rigid Loop Festoon bulb $ 4.95 $ 0.00 Cool White RL4410-CWHP9 1.00
$ 5.95
2 WLED-x5 LED Wide Angle LED bulb $ 2.99 $ 0.00 Cool White WLED-CW5 0.95
$ 7.88
2 WLED-x5 LED Wide Angle LED bulb $ 2.99 $ 0.00 Amber WLED-A5
$ 5.98
2 WLED-x5 LED Wide Angle LED bulb $ 2.99 $ 0.00 Red WLED-R5
$ 5.98
3 921-x9 Wedge Base LED bulb $ 1.95 $ 0.00 Red 921-R9
$ 5.85
2 921-x9 Wedge Base LED bulb $ 1.95 $ 0.00 White 921-W9 1.75
$ 7.40
These are all from the superbrightled.com website...I also saw a rechargeable LED spotlight for $20 that charges via the cigarette lighter...thought that would be pretty handy to have...does anybody have one?
turbochargedss2012
Sep 20, 2023 12:17 PM
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
