What are the best HIDs for the cobalts? And other HID related questions
Old Aug 30, 2009 | 07:03 PM
05RLS2's Avatar
I am wanting to go with a set of HIDs, but I am unsure what kits work these best in these cars. What brands would you all reccomend?
From what I have read before, since we have 9007 bulbs that use a single bulb for low and high beams, using a low beam HID kit will cause the high beam indicator on the dash to be constantly illuminated with the lights on. Have you all had this happen?
Also, is the stock harness able to supply enough power to light the HIDs at startup wiothout any problems, or is it a good idea to get another harness to run the power off another source?
Old Aug 30, 2009 | 07:42 PM
Icydub's Avatar
Most people get projectors with HIDs
Old Aug 30, 2009 | 07:45 PM
TommyP's Avatar
AWD > FWD
Ya, that's recommended so that you don't blind people, retrofit projectors recommended over ebay ones for the absolute best light. The stock reflector housing produces tons of glare with hids and will blind people which is dangerous. Most people will give you a on using hids with reflector housings. And yes, you will need a relay harness so that you don't harm the wiring, unless you get a kit that has the relay built in. Bi-xenon will allow you to keep the high beam if you use the stock housing. If you get non-retrofit projectors, you will have to get a low beam only kit.
Old Aug 30, 2009 | 08:24 PM
05RLS2's Avatar
I will probably just go with a low beam anyways since it should give more than enough light. What about the high beam indicator on the dash, does it stay illuminated for you all?
Old Aug 30, 2009 | 08:29 PM
Redsaturn13's Avatar
No
Acey's Avatar
Yeah HID's aren't even necessary as high beams as well in fact it's not a bad idea to keep some halogens in there. And no the high beams won't be on unless you turn them on...
Old Aug 30, 2009 | 08:43 PM
05RLS2's Avatar
Good to know I don't have to worry about the indicator being on.
Now on to kits, what kind do you all reccomend? I am not going to penny pinch on a kit when I can get something good, so whatever is good I'll get
Old Aug 30, 2009 | 10:11 PM
oowah's Avatar
If you're not worried about the cost, then get projectors or retrofit - no question. It's the right way to do it and everyone on the road will thank you
Old Aug 31, 2009 | 10:32 PM
05RLS2's Avatar
I wish there was as many options for projector lights out there for the Ion as the is for the Cobalts, but there isn't a single projetor light set available. I don't mindd spending a couple hundred on a good kit, retrofits are a little more than I want to deal with
Sean Cummings
Jan 8, 2020 10:17 AM
Turbo Johnny
Feb 21, 2019 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Jacque8080
Sep 9, 2015 09:21 PM
