Wheel Spacer on rear drum
Old Mar 28, 2011 | 11:33 PM
e-bone505's Avatar
can u install wheel spacers on rear drums, since the base models have a drum in the back...does any one know. cause thinking about buying some
thanks,eric
Old Mar 28, 2011 | 11:34 PM
1angry_cichlid's Avatar
Actually I'd be curious too- I have rear drums too. Lol that sounds dirty.
"yo check out my drums yo"
Old Mar 28, 2011 | 11:36 PM
e-bone505's Avatar
haha...if we can get someone to answer this for us, that will be great for a good stance on the base model with lower springs
Old Mar 28, 2011 | 11:51 PM
boost_junkie16's Avatar
Of course you can. You're wheel mounts to the drums exactly like it mounts on your rotor. Anything over 5mm and you're going to need longer studs.
Old Mar 29, 2011 | 12:39 AM
Hammbones's Avatar
What's the point besides a 10mm wider stance?
Old Mar 29, 2011 | 12:47 AM
Old Mar 29, 2011 | 11:07 AM
e-bone505's Avatar
5mm isnt that thick tho...
Old Mar 29, 2011 | 05:08 PM
e-bone505's Avatar
why would u need to get longer studs...if the spacers already has studs on them
Old Mar 29, 2011 | 05:10 PM
It depends on the size of the spacer. If you're running a big enough spacer that it had studs in the spacers as well then you won't need longer studs.
Old Mar 29, 2011 | 05:17 PM
e-bone505's Avatar
do have spacers....if so, wat sizes are urs
Old Mar 29, 2011 | 05:29 PM
Hammbones's Avatar
10mm wider on a car thats 5-6 feet wide doesn't really seem necessary unless you're trying to squeeze something in behind the rim like a Brembo Kit...
Old Mar 29, 2011 | 05:52 PM
e-bone505's Avatar
so a 5mm, would be better and safe
Old Mar 29, 2011 | 06:39 PM
C_A_D88's Avatar
id go atleast ten
it also depends on the rims your running...if you have an ide how much more you want your wheels out, just measure 6mm is 1/4 inch
Old Mar 29, 2011 | 06:40 PM
C_A_D88's Avatar
for instance with my tc rims to get my tire flush i would need about an 8ish
05Slowline's Avatar
should get rear disc brakes first cause you'll get made fun of for them I know I'd make fun of any car I saw with drums that thought their **** was hot LOL.
Old Mar 29, 2011 | 07:19 PM
C_A_D88's Avatar
loser...
Old Mar 29, 2011 | 09:17 PM
5mm would be safe on stock studs
This. I run 8mm and extended studs. They're pretty flush.
You're kidding right?
Old Mar 29, 2011 | 09:20 PM
05Slowline's Avatar
loser...
aww do you have drums
nope
Old Mar 29, 2011 | 09:25 PM
Tons of people run drums. What's the big deal? A car can look nice with drums, it really isn't a big deal.
Old Mar 29, 2011 | 09:29 PM
05Slowline's Avatar
because outside of your bubble you live in, you will get laughed at, drum is synonymous with base model...just the way it is...
Old Mar 29, 2011 | 09:30 PM
So you'd laugh at a 2.2 putting down 300 or 400whp? You sir, are an idiot.
Old Mar 29, 2011 | 09:36 PM
05Slowline's Avatar
and not having the ability to stop from it, LOL!
Old Apr 9, 2011 | 12:55 AM
NathanSS's Avatar
Drums would be fine I would think... Id also though, if going to over 300 horsepower and using it.. lol... get some solid brembo big brakes up front. Cant laugh too much at those...
Old Apr 9, 2011 | 02:27 AM
xdjstylz330x's Avatar
Personally, i think drums hold up for breaking better than disks for small cars. In a heavy ass full size its needed, but on a compact....ehhh.. I had an 07 ss/sc, have a 2.2 ls, and screwed around in a ss/na. I just felt more breaking and hold in the ls vs the ss/na with rear disks. Altho brembos will be better than stock reguardless. But thats just me. All around disks look way much better. Just depends if you like looks or not. Ither way, its your car. Not no one elses.
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
goaliemo
Sep 28, 2015 01:37 PM
