why do the fogs go out??
1) If it's foggy out, you shouldn't use high beams so there's no real need for the fogs if your brights are on.
2) Also, probably the real reason they did it is some places don't allow you to have high beams AND fogs on at the same time.
This isn't the first car I've seen that disables them. A lot of cars also won't let you run the fogs only without the headlights, but for some reason ours will.
