wider tires
wider tires
I've read on the forum and other places that its possibe to mount a wider tire on the cobalt SS/SC rims is this true? also how wide can you go? and how is it possible?
thanks in advance
thanks in advance
Originally Posted by VaMP
Err I wouldn't imagine it isn't possible because our 'performance' handling is largely do to our skinny tires, therefore tire hanging over the rim is just going to to do more harm then good...
please tell me how skinny is better, not doubting that you could be right just very curious
I think what he meant was this.
You want to match your tires to your rims. You want the rim to sit right inside the tire, with just a little overlap. You want the rim/tire assembly to look like a rectangle not a donut.
Moving to a larger section width may make the tire a tad bit wider but it also makes for more slop in the sidewall.
DANRICKARD
Oct 1, 2015 12:08 AM
