Wingless question
Old Jun 17, 2012 | 10:40 PM
Wert842's Avatar
Wingless question
I've been throwing around the idea of going wingless on my cobalt. I like some pics of some cars with the high rise spoiler and others without it. I'm wondering if I take mine off, what do you guys use to fill the holes that in the trunk? If I like it I might just swap trunks or get mine repainted and fill them correctly, but I'm just looking for a temporary solution right now.
Old Jun 17, 2012 | 10:43 PM
nhanson's Avatar
washers, bolts, nuts (my buddy put a rubber washer under his metal washer for sealing and so it doesnt scratch)
Old Jun 17, 2012 | 10:51 PM
cmatthewb101's Avatar
Vinyl, duct tape, black electrical tape, scotch tape, hole plugs, butt plugs, dead persons finger, a *****.
All kinds of ways
Old Jun 17, 2012 | 10:52 PM
robd53's Avatar
I originally took the highrise off my trunk but it looked like crap underneath, and removing all the adhesive was next to impossible. I got it all off, and you could see small indents where the pedestals sat. I used plastic body plugs from autozone to fill holes.
Personally, I thought it looked like ****. I found a wingless trunklid and went that way instead, it was $150 at the junkyard and likely cheaper than filling the holes.
Anyways yes, I used black plastic body plugs with a little silicon on each one for a temporary solution.
Old Jun 17, 2012 | 10:55 PM
bluestreaks's Avatar
things you might need:
fiberglass cloth. home depot
fiberglass hardener. home depot
body filler. home depot
sand paper home depot
paint that matches your color automotivetouchup.com
clear coat. any clear coat.
go to home depot grab some fiberglass cloth and fiber glass hardner put the cloth and fiberglass the inside of the trunk and cover the hole, then get some body filler fill the top of the hole, sand it down, buy some matchup paint from automotivetouchup.com, paint it and clear coat it .. no one ever has to know.
do the same with the inside so it dont look like poop
Old Jun 17, 2012 | 11:02 PM
Wert842's Avatar
Haha. Wow those are a bunch of ways to fill them. I want to find a way that kind of still looks flush but doesn't bulk it up as using some washers and bolts and stuff.
Old Jun 17, 2012 | 11:07 PM
robd53's Avatar
Check this out:
Temporary Removal of the Spoiler
Yes, it's a Mustang but same concept.
Old Jun 17, 2012 | 11:08 PM
if you sand it down smooth and it will look like you never had a wing on it
Old Jun 17, 2012 | 11:18 PM
rivaladore's Avatar
I bondo'd and rattle canned mine, came out ok. Autozone and strauss has gm color matched spray paint, sand paper and clear coat. Definetly going to redo it though and take my time. I was rushed when I last did it, gf was bitching that the paint smell was coming in the house and I was getting bit by mosquitos.
Old Jun 17, 2012 | 11:21 PM
Wert842's Avatar
Originally Posted by robd53
Check this out:
Thanks! That's about exactly what I was looking. I might just go about looking for something along those lines tomorrow.
Old Jun 17, 2012 | 11:23 PM
rivaldore did it right and came out awesome. just the way i did it with the prelude
Old Jun 18, 2012 | 12:12 AM
Florida 76's Avatar
if you want to go wingless just bondo the holes then sand.... then wrap the trunk in carbon fiber wrap.... i broke my small wing so i added this big one... i dont like the wing less look it looks too bare
Old Jun 18, 2012 | 12:13 AM
matt638's Avatar
leave the holes unfilled, let water seep through and make your trunk a hot tub.. thats what I did, best mod yet
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
