Zero Emblems
Zero Emblems
just curious to know what i should expect to pay when getting my car shaved? (emblems, and that plastic strip down the side of the car)
and possible the handles
You should debadge and de-strip yourself, but if you want the door handles shaved, buy my kit I have for sale!
https://www.cobaltss.net/forums/parts-66/sale-shaved-handle-popper-kit-144766/
start with a hair dryer on the emblems not to over heat enough to soften the adheisive then with a plastic wedge very slowly work at the adheisive (a spreader is ideal) kind you use to spread body filler
http://www.thehoffmangroup.com/c/sha...evrolet_Cobalt
https://www.cobaltss.net/forums/showthread.php?t=144766
i just did mine, i used a plastic paint scrapper, worked fine,...
what else would you use?
i also used hair dryer, and goo gone,
i went to an autobody store told me how to do it i got off school early and had 10$ in my pocket and thought what could go wrong...
only problem im having is i find that the area i used the goo gone is really fogy and water beads right off it, so i find it hard to wash there, but i did it like 20 mins ago, lol i think ill take the electric buffer to it later..
I had the same problem with that last little bit of glue that didn't want to budge, I used a 1500 grit rubbing compound (3M) and then a little NuFinish Polish after it was gone. Worked like a charm.
The problem with using scrapers or plastic pieces to pull the things off is it tends to pull it off on an angle which digs the corners on the side that is farthest away fron the scraper into the paint, leaving little divits of mising paint.
IMO 40lbs fishing line is the way to go
QFT!
NOOOO... one... its a waste of money and gas, two it takes forever to get off of you, and three its terrible for your paint and clear. Use something DESIGNED for taking sticky stuff off of cars.... Like goo gone
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
