Extended lug studs
Extended lug studs
Alright to fit the 265 dunlops on the front I'm going to seed some more room in the front so maybe a 5mm space if not a bit more. I personally believe that if you go over 3mm for a space that you should run extended studs.
Anyone know where I can find some extended lug studs and maybe some lug nuts to go with them?
Let me know! Thanks guys!!
I got the 7708s too (from Jegs) and no way in hell you can get them in without removing the hub.
I'm gonna pickup a set of Moteki sr48s as the stock lug nuts are just about bottomed out.
The hubs will need to be removed for the front, but they fit in the back just fine. I hammered out the stock studs and stuck the new ones in and sunk em in by threading on some lugs and torquing them down
Turbo Johnny
Feb 21, 2019 09:41 AM
royce777
Sep 28, 2015 07:11 AM
