Autocross and Road Racing Road racing is not “street racing”
Raybestos ST-43 brake pads
Old Jul 7, 2012 | 12:54 AM
Wangspeed's Avatar
I'm tired of Cobalt Friction XR1. They're dying in 2 days now, and at 260+ a pop, that is not cheap. Andie @ Cobalt says it's ABS related, but I don't buy it since it's rare that I engage it. I don't seem to be the only person with this issue either.
A lot of the Evo and STI guys are moving to Raybestos pads, so I'm going to give these a try tomorrow. It's going to be 105F out, and I'll be putting these ST-43 pads to the test!
As usual, I'll post my thoughts on them after this weekend, if I survive the heat. If you don't hear from me, look for me in a hospital with an IV hooked up to me
Old Jul 7, 2012 | 01:54 AM
noorj's Avatar
Good luck!
Old Jul 7, 2012 | 02:07 AM
09sscalicobalt's Avatar
haha goodluck btw did you gety your rear axle bushings in yet and how much do those suckers cost for a set wang?
Old Jul 7, 2012 | 11:24 PM
Wangspeed's Avatar
The pads worked out great today. It was MISERABLY hot. 105F, and humid. No signs of crazy wear, but my brakes are getting HOT.
Quite happy with the pads. It's almost impossible not to trigger ABS going down into turn 5 at Summit Point. It's really bumpy, and will set off any modern day ABS. Even still, no excessive wear.
Old Jul 7, 2012 | 11:33 PM
wrxpappy's Avatar
I'm really looking forward to the results on these. I'm blowing through stock pads in 5 sessions and the stock pads really aren't very consistent.
Old Jul 8, 2012 | 02:39 AM
noorj's Avatar
What are those cracks on the rotor? I'm assuming from heat but IDK
Old Jul 8, 2012 | 06:01 AM
Wangspeed's Avatar
Normal surface cracking. It's when it goes through the rotor, or to the edge where it's an issue. This is why drilled is absurd. It likes to play connect the dots and split wide open.
Old Jul 8, 2012 | 04:48 PM
FasterIsBetter's Avatar
Congrats on the find! Didn't know raybestos made pads for our cars. You know you can pull the abs fuse right? Tbh I think abs messes me up, its only good for dding. We also pull the abs fuses on our 4x4 rigs because in mud, abs doesn't help...
Old Jul 8, 2012 | 05:20 PM
haha i can only imagine wang
Old Jul 8, 2012 | 05:49 PM
ItalianJoe1's Avatar
The rotors I pulled off my Z yesterday looked like that, and it's never seen the track, just me abusing it on the street daily with hawk HPS pads and factory brembos.
Old Jul 8, 2012 | 06:12 PM
07cobaltguy's Avatar
wow i must not be pushing mine that hard. Ive never seen that surface crazing before.
Old Jul 9, 2012 | 09:49 AM
Wangspeed's Avatar
Well, these rotors are done Lasted a year. Not bad. I can catch some of these now with a nail. The pads were awesome. They were pretty easy to modulate, and never gave up on me. Super consistent. That said, I've got to get some air to the brakes. I think that'll drop my lap times more than anything else. I don't even hold the throttle all the way to the brake zone anymore, in an effort to slow brake wear.
Old Jul 9, 2012 | 10:14 AM
Powell Race Parts's Avatar
raybestos make good pads for sure, good work Warren. Brake cooling a few days away on my part...
Old Jul 14, 2012 | 01:34 PM
madcitySS's Avatar
Where can you buy these pads? I'm doing a track day at road America this October. Since IRS my 1st time there I was thinking about some hawk pads.
Old Jul 14, 2012 | 03:56 PM
Wangspeed's Avatar
Call up Wendy @ Porterfield. They make the Raybestos race pads. (949) 548-4470.
FMSI number is D1379
Old Jul 17, 2012 | 12:46 PM
madcitySS's Avatar
do you think I would need pads being its my 1st track day at road america and i assume ill be in the beginer class? Im just debation cause I know I wont go all out but i do want to push the cobalt a bit. Just wondering if ill get enough heat in them to make them work well.
Old Jul 17, 2012 | 10:08 PM
Wangspeed's Avatar
Given that you have a fair amount of car control experience w/ AX, I would recommend either going easy on the throttle on the straights, or getting a set of Raybestos, which will last you a long time. It's nice not having to worry about fade or inconsistency.
Old Jul 17, 2012 | 10:39 PM
madcitySS's Avatar
Good call. Do you run those pads everyday? Or just thrown them in before a track day?
Old Jul 18, 2012 | 09:15 AM
Wangspeed's Avatar
I throw them on just before going to the track. I drive to and from the track without an issues. They have plenty of braking power even when cold, and so did the Cobalt Frictions.
Old Jul 18, 2012 | 11:45 AM
madcitySS's Avatar
cool. Thanks for the help!
Old Aug 2, 2012 | 12:52 PM
wrxpappy's Avatar
I just put a set of ST 43 on the car. Best braking ever for me on the track (only used stock and HP+ pads before). Lots of pad left after 4 sessions. Wangspeed, thanks for the tip on oil (and pads). I didn't use any oil all day with the Mobil 1. I was using 1/4 a quart of Ultra per session before the switch. That's kind of a scary difference. I don't need to worry about the PCV thing now.
Old Aug 2, 2012 | 02:09 PM
Wangspeed's Avatar
More than happy to help out a fellow track rat
Old Sep 8, 2012 | 12:00 PM
Mark Aubele's Avatar
...This is why drilled is absurd. It likes to play connect the dots and split wide open...
Yep. These came on the rear of my Z06. I threw the fronts in the garbage, but being cheap I thought the rears wouldn't get hot enough to cause any issues. I was wrong, in three laps I heard a loud bang, then I saw this...
Traction, ABS and stability control disconnected for track use, so this is just from normal braking on DTC-30s....
Old Sep 10, 2012 | 09:08 PM
395 plus's Avatar
I have run 9 different events at Road America. Brakes are your friend there. You come into a lot of corners at over 100+mph. Its a high speed course. I ran race pads on dedicated rotors and it really allows you to get the most out of the car and tires.
I am curious about these pads as I noticed they had a number of different compound to choose from also.
Old Sep 11, 2012 | 09:24 AM
I also am trying Raybestos LNF rotors, less money than the Brembo rotors. Seem to be okay so far but the machining is not consistent rotor to rotor, so not sure yet. Early days for testing.
