Autocross and Road Racing Road racing is not “street racing”
Time Attack Cobalt choice.
Old Aug 30, 2016 | 09:51 AM
Xorak's Avatar
Hello everyone,
I looking to buy my first Cobalt and was wondering which would be more beneficial for time attack / auto cross. I've noticed a wide variety on the forums of people using either LSJ or LNF, as well as L61 in the case of Foximus Motorsport. So my question is if you could have any model of cobalt with a $2500 upgrade budget which would you get for time attack / auto cross.
Thanks
Old Aug 30, 2016 | 10:47 AM
Bass_Waves's Avatar
Most likely a lnf. With that 2500 ain't much you can buy. To make something as close to the lnf from a Lsj it will take a little more money but at that same token the Lsj would be a power house.
Old Aug 30, 2016 | 10:59 AM
Xorak's Avatar
Thanks for reply,
I can get an LSJ for $3500 - $4000 and a LNF for $7000 - $8000. Would the difference in price added to the $2500 be enough to make the LSJ a better option or would more money be needed?
Old Aug 30, 2016 | 11:08 AM
hawkssoccer11's Avatar
Originally Posted by Xorak
Thanks for reply,
the lsj is a great motor but so is the lnf. the lnf has a lot and when i mean a lot i mean a lot more torque when tuned. you can put a tune on the lnf and be at 300whp and 330-360wtq. then if you do a downpipe that frees up a lot more too. as well as an intake and other supporting mods. plus the stock suspension on the LNF is already really good.
for the lsj to get you power like the LNF you would have to run a TVS supercharger to get over the 300whp hump. on the stock supercharger with a heat exchanger, intake, header, downpipe, exhaust, say a 2.7 pulley, stage 2 belt, dual pass end plate, 60-80lbs injectors, meth kit or E85 youll be around 270-290whp.
Honestly though its all in how much power you really want man. theres endless possibilities but if i were you id go with the LNF.
Old Aug 30, 2016 | 11:18 AM
Haven07's Avatar
The lnf is definitely the better off the line choice. Better brakes, better suspension, and easier to make power....
For a dedicated autocross car I think a tvs lsj is "probably" the best but it would take quite a bit of money to get to that point. But with your budget grab an lnf...a tvs lsj will require a lot more money then a lnf lol
Old Aug 30, 2016 | 12:28 PM
Omiotek's Avatar
You need to figure out what class you want to run and that will help make your decision easier. Mods quickly rack up points.
I personally think the lnf is the way to go in this case.
Old Aug 30, 2016 | 12:57 PM
Xorak's Avatar
I would like to stay in the GT1 and lower class for a couple years at least. Not sure If CASC and SCCA have similar point value system and class requirements. Max you can have is 79.9 points before being pushed into SGT classes.
These are the base points for stock Cobalts:
LNF stock = 70.5 points(PI)
LSJ stock = 58.3 points(PI)
This is the rule book for showing points for upgrades:
http://www.casc.on.ca/sites/default/...ck_rules_1.pdf
Old Sep 8, 2016 | 01:07 PM
Viperoni's Avatar
I think the CASC Time Attack points rating system is different than the Auto-X guys, and definitely different than the CSCS folks up here...
That being said, will you actually be racing in the CASC Time Attack?
If so, I think the LSJ would be a bad option, and a couple small mods (Header and Koni's) will keep you in the same class and will give you a big handling and small power bump so you can be more competitive.
I almost joined the Time Attack a couple years ago and am reasonably familiar with the points system they use
Old Sep 8, 2016 | 02:06 PM
KylesMoney's Avatar
Hello everyone,
Thanks
I vote lnf. I only have a catless dp, intake and a tune, and I'm putting down 336whp & 377 wtq at 25psi. They can put down power with just a few mods, then it's whatever you can spend after.
Old Sep 8, 2016 | 09:43 PM
63 Nova SS's Avatar
Those numbers have to be on e85 or 47?
Old Sep 8, 2016 | 10:22 PM
If you're wanting auto-x get the LNF, the difference in knuckle design (iirc thats the part, someone who actually recalls correct me if i'm wrong) effects the turning radius. LSJs are stupid wide compared to the LNF
Old Sep 9, 2016 | 07:08 AM
KylesMoney's Avatar
Nope. 93 octane. Pwerks tuned it a couple weeks ago. Posted the dyno results shortly after.
Old Sep 9, 2016 | 08:27 AM
63 Nova SS's Avatar
Those are nice numbers
Old Sep 9, 2016 | 09:53 AM
KylesMoney's Avatar
Thanks, nova. I did some research on tuners around Illinois, found the best recommended (performance autowerks) and went. The base was 277whp (don't remember wtq) and Dave did an amazing job.
Old Sep 9, 2016 | 09:59 AM
63 Nova SS's Avatar
I have purchased several things from them. Omiotec used to work there. Wish their transmissions were cheaper I would have them do one for me. They are big in the solstice/srt4 merchandise.
Old Sep 9, 2016 | 10:33 AM
KylesMoney's Avatar
That's for sure. Quality products and services and good people.
Foximus
Mar 14, 2016 10:15 AM
vanos
Feb 11, 2016 07:28 PM
Eddie
Nov 29, 2004 03:50 PM
JonyyB
Nov 24, 2004 06:10 PM
JonyyB
Oct 23, 2004 04:19 PM
