Autocross and Road Racing Road racing is not “street racing”
Types of rotors used?
Old Sep 16, 2012 | 04:03 PM
Nfamous60's Avatar
Hey just wanted a Idea of what type of rotors your guys that track your cars are using. I read a thread on a new brake pad and i guess cross drilled is bad with surface cracking?? just wanted some insight form guys who hit the track if just for a weekend thing... also are you using the Gm after style rotors or power slot?
Old Sep 16, 2012 | 04:13 PM
matt638's Avatar
i've heard a lot of guys talk about the stock rotors being the best for track use
Old Sep 16, 2012 | 04:14 PM
09sscalicobalt's Avatar
stock rotors stock pads ss line and wilwood 570 fluid works great for me
Old Sep 16, 2012 | 04:18 PM
Nfamous60's Avatar
^^ is that just for the weekend? or you daily drive around and track on weekend, im up to brake mods just seeing if it worth spending more or just sticking with stock.
Old Sep 16, 2012 | 04:19 PM
FrossB's Avatar
Thread Killer
Stock pads are pretty much the best. Probably wouldnt hurt to upgrade to SLOTTED rotors. Not drilled. SS lines are going to be an upgrade. And as said above...some guys like to change their fluid.
Old Sep 16, 2012 | 04:24 PM
Nfamous60's Avatar
ordered the Th motorsports brake line and clutch line set, clutch line in yellow brake line in black, tryin to build my cars together to aviod issues i dnt want to do a hub swap. sumone said no point n getting wider tires so i guess im sticking with the 18x8's might get the PF01's...
Old Sep 16, 2012 | 05:07 PM
daily drive and track with that setup no need to waste money and r1 rotors are ****...
Old Sep 16, 2012 | 05:55 PM
Omiotek's Avatar
them technafit lines are crap..... goodridge are the only good ones for the lnf.
no theres no point in WIDE tires like auto x guys use but wider could definately help. and theres no point in anything larger then a 235 on a stock rim. i run a 245 40 18 on a 18x9.
coleman rotors with ferrodo pads up front for track use and i just swap pads to cheapo pads for the street but use the same rotors , ac delco rotors out back with ac delco pads have proved to be just fine.
then i run motul fluid all the time and i bleed the brakes before every track event flush at the end of the track season. this setups never failed me.
Old Sep 16, 2012 | 11:15 PM
Wangspeed's Avatar
Stock or Centric premiums, which are the same as the R1 premium. No slots, no drilled holes.
Here are my stock rotors after some track abuse.
If they were drilled, they would be split all the way through, and risk massive brake failure. But instead, these hold together just fine, and last for many brutal track outings.
Old Sep 17, 2012 | 03:05 PM
Nfamous60's Avatar
nice thanx for the comments more then appreciated man trust me.... would you say goin down to a 17" rim would be beneficial? i'll sticc with stock rotors and pads for now will upgrade the fluid and try those for a session or two.
Old Sep 17, 2012 | 06:29 PM
Mark Aubele's Avatar
This is what happens to a cross-drilled rotor after ~4 hard laps on track on a rear rotor (car came with them, thought they would be OK on the rear), on a car that is by no means underbraked (C5 Z06)...
Slotted aren't much better. Leave the drilled and slotted for the "stanced" crowd.
Old Sep 17, 2012 | 06:54 PM
Omiotek's Avatar
theres nothing wrong with proper slots.... i run slotted colemans.... best rotors available for this car.
Old Sep 18, 2012 | 12:21 AM
They are pointless.
Old Sep 18, 2012 | 11:55 AM
Wangspeed's Avatar
Originally Posted by Mark Aubele
They are pointless.
Yeah, I don't like them either. Yes, they can serve a purpose, to provide more bite, but they tend to fill up with rotor slag, and you have to dremel the slots back out, otherwise it looks like it's almost a blank.
Old Dec 14, 2012 | 12:20 PM
daregooch's Avatar
Stock ones are great, ebc blanks were complete garbage for how fast they warped, and now im on power slot slotted and they seem to be holding up fine.
Old Mar 28, 2013 | 04:19 AM
PyroSiege's Avatar
I'm using Powerslot Slotted rotors on my car right now and they are holding up great. I have been using Carbotech AX6 pads (They are made more for Autocross than track racing but are working fine for me. Might try an XP8 or XP10). I've been racing mostly at Stratotech in Fort Saskatchewan, Alberta which is known for being extremely hard on brakes due to being a short track with lots of tight corners (brakes don't get enough time to cool down properly between corners).
I've learned a few things about braking from this track. Stainless brake lines are a must, Having a good fluid like DOT 5.1 or a High Heat DOT 4 is a must (I still managed to boil both by the 9th lap. I have to get those stainless lines and figure out why I'm boiling every time!), and having a proper track pad for your car is a must too.
I looked at getting replacement factory pads for the brembos and the dealer wanted almost 400 bucks for a set... Fuuuuuck that. So I put Hawk HPS on when I'm driving on the street, then I switch to a track pad just before the track day. Works great for me.
You guys still using stock pads, do you ever get any brake fade? How hard are you braking? What is the track like that you are racing on? I found the stock pads good, but I've been told they can't match a good track pad for bite and fade resistance. Unfortunately my pads were worn out before I raced at Stratotech for the first time, so I never got to try them out.
Old Mar 28, 2013 | 04:24 AM
PyroSiege's Avatar
Sheesh, how much abuse have those rotors seen? Mine don't look nearly that bad.
Old Mar 28, 2013 | 04:26 AM
Omnigear's Avatar
brembo BBK from powellztorox0rzj00rb0x0rz
he goes to a big boy track
Old Apr 19, 2013 | 09:33 AM
NickD's Avatar
For the guys who track and DD their cars. I want to eventually make it to a separate set of pads/rotors for street vs. track use. Have you had any problems with swapping them? Do you swap just the pads or pads and rotors?
Old Apr 20, 2013 | 01:27 PM
colodude18's Avatar
I use Hawk DTC-70 on all 4 corners with a separate set of rotors for the track. That way you don;'t have the re-bed your brakes every time.
@Pyrosiege do you upgrade only your front brakes with track pads?
You may be overheating your front brakes by changing the brake balance if you're running a mediocre pad in the rear. Try changing out the rears with the same pad.
All my rotors are solid.
Also, if you track you Cobalt hard, you will need to rebuild your Brembos on a regular basis. All the rubber boots and rings will melt at extreme high temps. Check them when you swap out pads. crateenginedepot sells the rebuild kits.
I use Prospeed brake fluid which has a boiling point of 683F. Highest on the market today.
Old Jun 11, 2013 | 01:10 AM
PyroSiege's Avatar
That's funny. Because a lot of very experienced people have said Stratotech is harder on brakes than longer tracks. So technically, "Big Boy Track's," are easier on brakes because they allow the brakes to cool more between corners.
Thanks for the info, I'll definitely look into rebuild kits, my Brembos are a little on the rough side right now. Also, I think ill try putting the equivalent pads on front and rear, maybe that will spread the heat out a bit more. I'll think about having a separate set of rotors for the street vs the track, too.
Old Jun 11, 2013 | 01:26 AM
Omnigear's Avatar
watch wangspeed runs on VIR
Old Jun 28, 2013 | 03:33 PM
colodude18's Avatar
In case you're interested, I just made a how-to on rebuilding the Brembos, linky here:
5280cobalts.com
Old Jun 28, 2013 | 03:59 PM
NickD's Avatar
colodude18: Great write up. I'll probably be hitting this up at some point. I have 2 days at Watkins Glen coming up, I'm guessing I'll be doing this at some point after that.
Old Jul 5, 2013 | 08:42 PM
Solaris99's Avatar
I have 9 track days (road courses) on PowerSlot slotted front rotors from TireRack and they've held up well. I'm now seeing more severe heat checking (almost as bad as Wangspeed's), so I'm done with them. I've been using CarboTech XP10s since day 1. For the rears, I had been using cheap street pads for 7 days, but didn't like the bias and having to "chase" the rear end in heavy braking zones. So I started using XP10s on solid rotors on the rear. 2 days on that setup and really happy with it.
Also, since somebody asked, I use different rotors and pads between street and track, of course.
