Backyard Turbo Backyard Turbo is a Supporting Vendor
Donkeyballs BYT EFR Build
Old Jun 22, 2011 | 02:42 PM
BYT*SS*TURBO's Avatar
Thumbs up Donkeyballs BYT EFR Build
Ill start this thread with what everyone wants to know: NO, this is not a direct bolt-on to the stock manifold. If that's what you are after then you will have to keep waiting for the ZZP EFR.
What ours includes:
  • Choice of 6258 or 6758 EFR Turbo (We can also build it to use the larger versions if you wanted!)
  • BYT 304SS Tubular Manifold w/Merge Collector
  • BYT 304SS Downpipe, can be Catless, Catted or Modular w/removable Cat or Cutout!
  • BYT 3" CAI or SRI
  • BYT "Stealth" Charge Piping (upper and lower are included)
  • Your choice of FMIC's or use your current aftermarket FMIC for a discount!
  • Oil/Water Lines
  • Installation AND Custom Tuning
*All of the BYT parts listed are built by us in-house! Nothing is outsourced!*
Some note worthy features:
  1. With any version of our Downpipe, you can easily mate to the stock exhaust or ANY current aftermarket exhaust on the car!
  2. You get a choice in which FMIC you want, you can also use ANY current aftermarket FMIC for a discount!
  3. You can also use either the stock Lower CP or ANY current aftermarket Lower CP you have for a discount!
  4. If you already have a Forge BPV, it can be used on the EFR Turbo!
  5. You get a choice in which Downpipe style you want, the Modular w/High Flow Metal Cat or Cutout is an extra fee.
  6. You can also opt to add any BOV you like and block off the BPV. (additional fee for the BOV and Block-Off Plate)
  7. With our kit, the piping is all routed underneath the car for a STEALTH look!!!
  8. The car performs like stock around town with insanely quick spool up and plenty of top end still!
My impressions of our kit:
When you pop the hood it looks like nothing is done! In fact, you have to really look to see if it's even a turbo car (if you don't know anything about the SS/TC's that is). That part of it I love! All of the other cars we have made Turbo Kits for in the past were the same way. So, that was our main goal when making this kit. The CP from the turbo to the FMIC (what we would normally call Upper CP) is routed under the engine and is NOT the lowest point on the car. Donkeyballs' car is quite low and we have yet to hit that pipe on anything!
First startup with the kit on, you can hear an immediate difference in the exhaust note. It sounds much deeper then stock and just plain sounds sick when WOT! With the base map loaded we took the car out for a first drive. I was expecting a little bit of lag but in reality it drives very similar to stock, VERY responsive at any RPM in any gear! In fact, the spool-up is almost identical making the car great for around town or Daily Driving. When you look at the Dyno Graphs posted below you will see it performs very similar to the stock turbo low end Torque wise. The big difference is the additional 70-80 whp up top. The car pulls hard right away and doesn't quit until you shift!
Last night we took the car to the dyno to run the new kit. I was feeling like it was around 380whp on the butt dyno. Sure enough, the first pull it did 390whp at 24psi. We tried several scenarios on the dyno, all netting similar results. Little more boost, the car knocked up top with similar to stock peak timing. Dropped it down just a tiny bit and tried a little more timing, similar results. The best run of the night it popped off a coupler mid pull You will see in the graph it was on it's way to being the best run of the night. All of the pulls were between 380-400whp and 380-400wtq as well. He is only running Pump Gas for right now, and without Meth. So as we kept adjusting the car we saw immediately this was a limiting factor. Donkey also needed his car back and we decided to just leave it there and play is safe for now. The plan is to meet up and try a E Blend after he drives and enjoys it for a little bit. We have another car sitting here to install a kit on a LSJ and then another LNF right behind it. So, we will have more results with different setups very soon!
Onto the pics:
(Some of the pics shown were during the process, just a FYI)
(Stock Turbo vs 6758 EFR)
(Lower CP)
(Treadstone FMIC w/Elbows welded on)
(We need a tighter 90* then a regular mandrel bent 90*, so we made our own)
(Smoooooth on the inside!)
(Modular DP setup)
(Top View, everything installed)
(Bottom View, everything installed)
(Another Top View, everything installed)
(Top/Side View, everything installed)
Dyno Graphs:
(This was the first pull on the dyno)
(A few overlayed, best run in bright green cut short )
YouTube - ‪BYT EFR - Cobalt SS/TC‬‏
The Pricing:
  1. 6258 or 6758 BW EFR Turbo (your choice)
  2. BYT Tubular Manifold
  3. 3" Catless or Catted DP
  4. 3" BYT CAI
  5. Both Charge Pipes (includes Couplers w/T-Bolt Clamps)
  6. Choice of FMIC
  7. Oil/Water Lines
  8. All New Gaskets
  9. Borg Warner High Boost Actuator
  10. Installation
  11. Custom Tune (not a generic file for all kits, it's tailored to YOUR car!)
Total = $5,000 USD
You will need a stronger clutch then stock with this kit, we install them for: $400 + Fluids/Tax
Re-use current AFTERMARKET FMIC: Subtract $300
Keep Stock or Aftermarket Lower CP: Subtract $125
Modular DP w/Metal Core HFC: Add $250
Modular DP w/Electronic Cutout: Add $225
* Just to be clear again: Your current Intake, DP and Upper CP CAN NOT be used with our kit to subtract costs! *
* These are only available as described! Only the parts listed can be subbed out! They also will not be sold and shipped, it's available as this package only! This may change when we move to the new shop but currently we have no plans to change this! *
Old Jun 22, 2011 | 02:47 PM
Billig ss/sc's Avatar
That's awesome Nick!!! Stoked to finally see the results of build!!
Old Jun 22, 2011 | 02:49 PM
Sp3No's Avatar
Cannot wait to see this thing in person, very nice build/design.
Old Jun 22, 2011 | 02:51 PM
Supercharged Guy's Avatar
Very nice
Old Jun 22, 2011 | 02:52 PM
MastaShaKe_88's Avatar
droooool
07BoostedG5's Avatar
very nice layout, I like that the charge pipe is not over the engine like stock, great job!
Old Jun 22, 2011 | 02:59 PM
dayhoff35's Avatar
i like the hidden charge pipes, nice work.
Bl4des's Avatar
do you have more pics of that exhaust mani
Old Jun 22, 2011 | 03:01 PM
Chevycobaltss3's Avatar
Nice, i am considereing The EFR series for my car. I just tuned a few on a lsj and i love the spool time of the 6758 and i love the power. Your numbers are the same as mine just my tq is lower lol....
Old Jun 22, 2011 | 03:02 PM
Gremlin85's Avatar
Absolutely phenomenal work, Nick! This kit is really amazing.
I'm guessing with the placement of the new turbo and everything, someone would have to use your intake or could one just keep whatever they have (K&N, Injen, etc)?
Old Jun 22, 2011 | 03:04 PM
donkeyballs's Avatar
Sick car!
Old Jun 22, 2011 | 03:15 PM
zrated89's Avatar
charge pipe doesnt hit on the block by the mount?
Old Jun 22, 2011 | 03:20 PM
No.. My car is lower than 95% of cobalts and it wasn't a problem
Old Jun 22, 2011 | 03:55 PM
ctn2mb's Avatar
Is there a price on this? lmao. and I'm assuming you can turn up the boost if you got diff pistons, valve springs, connecting rods and such.
Old Jun 22, 2011 | 03:56 PM
There is a bracket on the bottom that attaches to the trans housing to keep everything in place and not hit. So far so good, haven't seen a mark on the pipe!
Jason just said he's coming to get it, Im sure he'll put up some more vids of it
There's def room to make more power on this setup. It's on the conservative side for sure as it sits but not at all a slouch!
Last edited by BYT*SS*TURBO; Jun 22, 2011 at 03:56 PM. Reason: Automerged Doublepost
Old Jun 22, 2011 | 05:43 PM
Have a bad ass ford focas rental and on my way! Turns out the rental guy is a css.net member and was at our last meet lol..
Old Jun 22, 2011 | 05:57 PM
TurboTechRacing's Avatar
Looks great! Nice to see this get posted
Old Jun 22, 2011 | 06:17 PM
Thanks Aaron, was a long time coming now! Jason def wanted/needed his car back but we wanted to make sure it was 100% up to par before his long trek back home. Not to mention, then 6hrs away with the car if something came up. I think once he drives it, he'll agree it was worth the wait. It really runs just flawless, the power is soooo smoooth.
Ive been talking with my other guys here and we may do a cheaper version that will adapt to other CP's and intakes. The manifold and DP will be a must tho, this DP is pretty tough to fit in there lol! Once we move to the new building we plan to do the GB on the CAI/SRI's and then possibly a "budget" version of this kit.
Im also toying with the idea of fabbing up one with a 7064 to test out with our Ported Head we're working on Time will tell. Right now our plate is full, so that stuff needs to get completed first thing!
Old Jun 22, 2011 | 07:29 PM
Omnigear's Avatar
twin scroll version or single scroll?
Old Jun 22, 2011 | 07:34 PM
Single, 6758 is only available this way... (T25 flange)
Unless you do the T4 flange then you can get the twin scroll. He has the T25 flange on this setup.
Old Jun 22, 2011 | 07:38 PM
Omnigear's Avatar
https://www.speedforsale.com/rx7part...1nib586nk1pqr6
chart says otherwise , hence i askd.
edit edit =p
just saw post ^
Old Jun 22, 2011 | 08:07 PM
BIG SS TC's Avatar
damn thats the black one u showed me!!!! very nice
Old Jun 22, 2011 | 08:14 PM
mkriebs's Avatar
Any pics of the manifold?
Old Jun 22, 2011 | 08:52 PM
Omnigear's Avatar
price breakdown?
Old Jun 22, 2011 | 09:46 PM
The chart above confirms what Aaron said. You can only get a single scroll setup unless you goto the large T4 housing.
