[ON] - In need of a throttle body
2007 Cobalt SS 2.4L
I am looking for a throttle body please within the GTA. I'm in Mississauga, would prefer to be as close to there as possible.
Please and thank you.
Found a throttle body, installed, still having issues. Sounds like excessive ticking/knocking. Could it be the timing chain is pooched? I'm around 125K KM's. Works fine aside from the knocking when easing out of the driveway, but give it gas and it bogs like its being flooded and has no go/*****
Used my HP Tuners, codes read;
[] P0013 - Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Bank 1 (History) (Immature)
[] P0014 - Exhaust Camshaft Position (CMP) System Performance Bank 1 (Old) (History) (Immature)
[] P0016 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor A (SES) (Old) (History) (Current) (Immature)
[] P0068 - MAP/MAF - Throttle Position Correlation (History) (Immature)
[] P0101 - Mass Air Flow (MAF) Sensor Performance (Old) (Immature)
[] P0446 - EVAP Vent Solenoid Valve Control System (Old) (History) (Immature)
[] P0455 - Evaporative Emission (EVAP) System Leak Detected (Old) (Immature)
[] P1174 - Fuel Trim Cylinder Imbalance - B1 (Old) (Immature)
And when I cleared the codes and rescanned, the P0016 is the only one that comes back
