Manitoba SS 2014
#1976
So when I first got my car I raced my buddies 08 SI and it was neck and neck tbh we both got a few kills and so I see this 2011+ SI when I was cruising tonight and at the lights we both go at it and I completely dusted him by 3+ car lengths and we did 2 pulls after, and each time I put lengths on him. So what gives? Why was it so close with my buddies 08 SI?
#1978
#1982
it was a roll in 2nd and 3rd gear. Because I now know that in 2nd gear at 4,000rpm that's it's sweet spot so I'm learning the car more and more
quick 75shot hahaha
quick 75shot hahaha
#1989
I read up about the cobalts IC pump problems so I'm actually going to check today to see if it's working because I know I have to fix a kink in one of the tubes.
#1990
Got Bewst?
An aero force interceptor is your friend and a great investment. It will allow you to monitor a ton of things. Like intake temps. Would tell you right away how well your system is working. And if I recall the tri pod on that car you have filled with boost, coolant or trans temp? and oil pressure gauges. Oil pressure is nice to see. Critical no. You could ditch the coolant/trans temp gauge and install an interceptor. Much more benificial. If you ever wanted a custom tune id ditch the oil pressure gauge for a wideband.
#1991
NOS gauge
#1994
#1995
Got Bewst?
Lol no he's not. And the bolded reasons are why. Also lacking a proper tune. If I had to guess i'd say he's probably around 270whp.
#1998
I like the supercharger though lol plus a turbo swap would be to expensive.. I just want to run full bolt on's and a tune. Was just curious on if it was attainable.
#1999
