I can send a timing map you guys can flash on that will be safe on just pump gas. Fuel mileage won't go up at all, but you can run crap gas and not worry about it popping if you gotta go WOT to pass a car or something. The just get the fueling nice and rich at WOT.
Why don't I just put your initial toon in the car with lower timing and richen it up a little? It's only 18* vs his current 22*
Yes I can adjust it for regular fuel. Even if 18* is too much I'll just pull a couple degrees out of the table. Unless Taylor is super bored and wants to send something lol.
Yeah just do that, thatll work. Just richen it up 5% or so and drop the timing 3-4* at wot for that 2.6. A 2.7 on 91 down here will usually take 14-15* up top as long as the pulls arent real long.
Roger that. Mike are you disconnecting your meth also? Id probably reccomend running it with such a small pulley. Not like you'll use much through the winter.
