Tuning Requests???
Old Oct 2, 2006 | 11:53 PM
meister's Avatar
Tuning Requests???
After over a month of working on a calibration for the Cobalt SS/SC, we are finally putting a bone stock cobalt SS/SC on the dyno this week. The only modification is NGK Plugs, one heat range colder with a gap of .035.
What I need from you guys is a list of requests and suggestions you would like to see in our tunes, primarily comprised of complaints about how the car drives/behaves stock and complaints bout other people’s calibrations.
There will be updates to our calibrations as HP Tuners ad’s features to the software giving me more control of drivability and fueling values. There are values in the GM PCM that HP has not included for various reasons. Every customer will be updated to our most recent tune, when it is available, free of charge
Among other unique features, we will be working on offering both 91 and 94 octane tunes built into a single flash/tune, giving drivers the opportunity to run both Sunoco E10 94 and Shell, Petro, or Esso 91, which is more readily available
Examples:
Drivability Concerns such s cold stumbles
Lack of power at cretin throttle positions and cretin rpm’s
Raise Rev Limiter
Raise Speed Limiter
Shut off rear O2 sensor (for off-road mid pipes)
Shut off EGR
Fix Speedo after gear change
Firm up shifts (automatics)
Turn off traction control permanently
Fan percentage increase
Adjust idle rpm
Throttle Response
Old Oct 3, 2006 | 07:20 AM
distillion's Avatar
yes!
tuning for both 91 and 94 is an amazing option,
i thin what alot of people want is a tune that will push the car to the limits given the modifications but maintain the stock driveability, i know some people have had idle surges in reverse or a choppy idle when swapped over to the 60's,
for me personally id love for my car to run the way it does now, maybe a lil better(improve over the gm flash) but tweak things that gm didnt do for us(torque management, better a/f, more timing, ect ect..)
paul if you are doin the cobalt any time after 330 let me know and like i said ill swing by and check this out.
Old Oct 3, 2006 | 07:23 AM
distillion's Avatar
for me cold starts are not an issue, i do warm up the car b4 i drive off, if i dont its a kinda choppy first to second shift, i may be interested in the rev limit being bumped a tad, id still shfit at 7 grand, thsi is to only insure i dont ping off the redline.
Old Oct 3, 2006 | 10:12 PM
player_1's Avatar
my biggest issue is driving with my untuned cams.
once the ferrea valvesprings come in, I'll switching over from my Bates and get it tuned, finally.
that and I'll need you to solve me P0017 code. I'll explain onceI'm ready I'll explain more.
Old Oct 3, 2006 | 11:46 PM
distillion's Avatar
alot of us tht have intakes must get them tuned for our specific set up, same with pullies, driveability is huge, smooth shifts, the way the car makes power as the rpms raise should be nice and smooth too, my gm updated stage 2 ALMOST cured all the driveability issues i was having, but i can still feel a lil imperfections since the stage flash is not meant for my smaller pulley and aftermarket intake.
torque managament disabled from second gear on, if enabled in any other gear,
pretty much sqweeze all you can but maintain driveability.
Old Oct 4, 2006 | 01:01 AM
meister's Avatar
Keep up the posts. Because I do not own one of these vehicles and can only simulate certain things on the dyno stuff like this helps and keeps people coming back. As I mentioned, any updates with our tunes will be passed on free of charge.
player, with the cams you will need to adjust a lot of tables to get the car running right. The P0017 code, is a crankshaft position sensor error and can be turned off with the HPT software. Because you changed cams, this is the reason the light is illuminating
Old Oct 4, 2006 | 10:46 AM
Mase's Avatar
Issue to look for: 2 out of 2 cobalts with intakes (injen, AEM) that I data logged didn't have the IAT1 working. Mine works fine, but I have a stock intake.
Old Oct 4, 2006 | 11:33 AM
distillion's Avatar
you back on the stockers for now??
Old Oct 6, 2006 | 04:58 PM
player_1's Avatar
nope I gotta a loner, I'm waiting for the ferreas.
Meister, how long do you think it would take to tune for my cams?
Old Oct 6, 2006 | 05:00 PM
meister's Avatar
Most tunes takes 1-2hrs....
Old Oct 7, 2006 | 07:50 PM
John's Avatar
do u think u can use that same tune as u did for my car being its an 07
since i got the same mod
Old Oct 7, 2006 | 09:50 PM
RG4's Avatar
RG4
how long will it take to retune the ecu with ur tune that u already did i have the same mods but w/o the plugs and whould that change the the effect of the tune if i still on stock plugs
Old Oct 7, 2006 | 09:58 PM
HackAbuse's Avatar
Originally Posted by meister
Examples:
Raise Rev Limiter
Raise Speed Limiter
Shut off EGR
Adjust idle rpm
Throttle Response
This sounds like 2.2 Stuff
Does this mean youre going to do some work on 2.2s ?!
Old Oct 8, 2006 | 12:32 PM
meister's Avatar
Yes, this tune will work on 07's no problem. It takes a few min to upload our tune to your PCM.
Yes, we will be doing 2.2's as well
Old Oct 8, 2006 | 01:39 PM
John's Avatar
ok so i may add that tune to my dyno day
see what it puts down before and after
hey paul could u get the 60 pound injectors for me as well lmk thanks
Old Oct 8, 2006 | 02:12 PM
meister's Avatar
Yup. We can get all parts for these vehicles just ask.
We list them for $78.00/injector. Plus you will need the harness/adapters
Old Oct 8, 2006 | 06:10 PM
John's Avatar
ok will talk on dyno day
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
