Calgary - random talk thread
Old Nov 28, 2015 | 09:29 AM
  #36801
kissrocker52's Avatar
Originally Posted by KMO43
I do not like interceptors
Oh. Which ones are good? The Plx ones are also ok sale.
I've heard nothing but good things about interceptors
Old Nov 28, 2015 | 10:49 AM
  #36802
heeter_33's Avatar
I have an interceptor and i like it. But it's basically a decoration at this point because my car is stock. Kmo likely has very good reasons haha.
Old Nov 28, 2015 | 11:06 AM
  #36803
soundjunky's Avatar
... zoomer did email me back;
apparently there is a discount applied to itmes in the cart today;
i logged back on to check it out...
the item i wanted the most was marked down yesterday to 207 from 269;
today the discount marks the same item down to 243...
don't get me wrong, a discount is great, but in my opinion their site prevented me from ordering at the $207 price - now having to pay $243 because I was unable to get on early enough to accomidate their site glitches during checking out is rather deflating.
Does anyone know if they have sales again akin to black friday right after christmas?
(when typically people aren't spending money)
becaue right now, i am kinda miffed, and spending an extra $36 because of a problem on their end doesn't appeal to me...
(and i am not going to whine and waste zoomers time about this)
Old Nov 28, 2015 | 11:25 AM
  #36804
soundjunky's Avatar
i have always thought that interceptors were a waste...
they show info that can be useful - but how many people actually tune using interceptor info?
... i'm guessing almost none;
the interceptor uses the same obd port that hpt needs to datalog and tune - while other gauges can be wired into hpt.
has anyone modified a coupe pillar, and added an rpd to a sedan before?
because they can be wired in...
the HHR monted the rpd on the dash...
and the rpd does show additional info that hpt can see & use...
thoughts?
Old Nov 28, 2015 | 12:13 PM
  #36805
InfraRedline's Avatar
The nice thing about an interceptor is that you don't always have your HPT plugged in, and you certainly aren't watching it during a pull or race. Say you have the interceptor set to monitor knock retard, and you set the alarm to go off at a certain amount. You get in a race and you are banging through the gears and something happens, whether that be a vacuum line popped off the wastegate or developed a leak and boost goes sky high, you nip a spark plug for some reason, you got a bad tank of gas, etc.. That red light will light up in your face and you will back off the gas and save your engine. Or say you are monitoring fuel trims while cruising around and you get a tear in a coupler or your maf screws loosen up or any sort of unmetered air issue, you'll notice that your trims are way off when glancing at your gauge. Or you set a boost alarm if the boost gets to a certain range on a cold night, or monitor intake temps so you aren't creating the sun inside your engine on a long pull. You can set alarms for any monitored function. Its just a nice peace of mind knowing that you can have something warn you if it has surpassed its comfort limit without you having to stare at the gauge mid pull.
I have one, but it hasn't been in my car for years due to some issues with it, so I am unbiased here lol, its just a nice piece to have in the car.
Old Nov 28, 2015 | 12:38 PM
  #36806
nathan112i's Avatar
i have one for the above stated reason, with no rpd in my car i wanted something to notify me if something went wrong and the car started knocking
Old Nov 28, 2015 | 04:34 PM
  #36807
KMO43's Avatar
No i dont have a good reason i just think theyre cluttered and i prefer gauges with needles not digital
Old Nov 28, 2015 | 05:55 PM
  #36808
Yea it would be for the above reasons too. Mainly now I need to buy 2 gauges lol. I have a dual pod on the way as well as I have the speedometer cluster with a single gauge pod.
Old Nov 28, 2015 | 09:12 PM
  #36809
soundjunky's Avatar
Kris - I don't know if you have heard of these, but for a while I was considering buying one of these to fill a pod spot;
I ended up adding an analog boost gauge (in large part because my RPD doesn't display vacuum) and an oil pressure gauge to my car.
Old Nov 28, 2015 | 11:27 PM
  #36810
Kris - I don't know if you have heard of these, but for a while I was considering buying one of these to fill a pod spot; I ended up adding an analog boost gauge (in large part because my RPD doesn't display vacuum) and an oil pressure gauge to my car.
Not a bad idea. I had never heard or seen these before
Old Nov 29, 2015 | 01:28 PM
  #36811
heeter_33's Avatar
I have an RPD, interceptor, and an analog boost gauge that I have yet to hook up because I haven't found the parts to do it yet.
Old Nov 29, 2015 | 01:42 PM
  #36812
KMO43's Avatar
I'm really happy i bought an AEM boost gauge since the RPD only goes to 25.5psi I've hit 34psi on my 7163
Old Nov 30, 2015 | 11:31 AM
  #36813
My boost, fuel pressure, and wideband gauges are all digital, and the only reason my Defi EGT isn't is because I already had it and AEM doesnt make a digital EGT gauge
Old Nov 30, 2015 | 01:35 PM
  #36814
What brand did you go with. I was also thinking I may switch to digital.
Old Nov 30, 2015 | 01:38 PM
  #36815
Everything is AEM besides my Defi EGT gauge.
Old Nov 30, 2015 | 04:07 PM
  #36816
mzspd's Avatar
What is everyone running for brake pads?
The previous owner of my car had the rear pads and rotors (OEM parts) done like 5k ago but they are grinding so I want to switch out those shitty OEM pads.
Old Nov 30, 2015 | 04:42 PM
  #36817
KMO43's Avatar
I'm running ZZP rotors with Hawk HPS pads
Old Nov 30, 2015 | 04:47 PM
  #36818
mzspd's Avatar
Sweet thanks, I ran HPS on my Speed and they were good. Did you get them from ZZP?
Old Nov 30, 2015 | 05:25 PM
  #36819
KMO43's Avatar
Ya. I'm still trying to decide between the ZZP big brake kit or just the ZZP rotors and HPS pads up front. I wanna run 17in slicks next year
Old Nov 30, 2015 | 06:40 PM
  #36820
Bluelightning's Avatar
Got Bewst?
Old Nov 30, 2015 | 06:44 PM
  #36821
KMO43's Avatar
It's true. I have a sexy RPD
Old Nov 30, 2015 | 07:11 PM
  #36822
Got Bewst?
RPD is good for a canned tune with minor bolts ons. Nothing more.
Especially if you don't have hpt to drive around with hooked up all the time.
Old Nov 30, 2015 | 07:45 PM
  #36823
KMO43's Avatar
Why is a RPD not good for a modded car? I can log my car whenever I want but I'm usually too lazy
Old Nov 30, 2015 | 11:37 PM
  #36824
Got Bewst?
You can just monitor wayyy more things on the fly is all
Old Nov 30, 2015 | 11:41 PM
  #36825
KMO43's Avatar
I don't usually look too much at my gauges I'm usually more worried about hitting **** at WOT
