Cruisn's turbo build
Damn you, beating me to it. Might have some questions for you when I'm installing mine. Except I get a ballin driveway to do mine haha. This shall end up as a battle of the turbo 2.4's!
#36
Update!!!
Tonight: Oil pan removed... lol. a little slack but had other fixin work to do.
The tranny:
Oilpan:
bottom end:
Oil squirter?
Randoms... lol. I was having some fun
The tranny:
Oilpan:
bottom end:
Oil squirter?
#40
Update:
well guys... its the half way point... well sorta. there is nothing left to remove and now it is time to start putting it back together... which is what I started doing tonight.. well injectors anyways. need to make a shoping list and get at er tomorrow night. expect a good update tomorrow for sure.
Oil supply line:
I am using 1 of 3 of the oil supply passages located in the back of the block. using the driver side one since the block heater blocks access to the first one. you can jsut see the top of the fitting peeking out behind the coolant line
Fuel Injectors:
Fuel rail removed:
Compare:
Old:
New:
Old harness: new one in the making tomorrow.
Oil supply line:
Fuel Injectors:
Fuel rail removed:
Compare:
Old:
New:
#48
rebuild is commencing. after today I am on hold until i can get my flywheel machined. anyone know any shops in edmonton??
The fitment is tight on the intake side.. I feel I might end up ordering a different manifold...
Fuel injectors installed with new wiring harness:
Oil pan return line:
Main Oil line:
Turbo in!!!
Boost gauge:
Main Oil line:
Turbo in!!!
Boost gauge:
