help!
Old Feb 8, 2010 | 05:20 PM
crueman's Avatar
help!
hey guys and gals, looking for some help, driving home today from work and i was almost home and suddenly loss power for a second then regained then lost it again and regained it again than it was fine. about an hour later i started it and it was idling strange, it would rev to about 2000 rpm than drop to about 500, and it kept doing it for about 2 minutes, then it seemed fine, went to drive and it acted like it had no power, after a couple minutes it smoothed out and was fine, any one have any ideas what it might be?
Old Feb 8, 2010 | 05:30 PM
DoMiStIc_RuSh_06's Avatar
Hmm.... My old ss/sc did that once and Never did find out what it was. As for the strange idle, my car did that all the Time when I came to a stop.
If you have warrenty, take it to the dealer
p.s. Would it kill ya to wave lol.....I drive my gfs yellow 07 lt with black steelies and yellow cobaltss.net decals in the back quarter windows
You do have an intake don't you.... If so your filter could be water logged due to all the water/ melting snow on the roads. Check the filter.
Last edited by DoMiStIc_RuSh_06; Feb 8, 2010 at 05:30 PM. Reason: Automerged Doublepost
crueman's Avatar
my bad sorry dude didn't see ya, next time drive at me or throw something lol, yes i got a warranty through kia that covers just about everything i can think of, i plan on going in to see them in the a.m.
Old Feb 8, 2010 | 05:32 PM
Lol it's ok....
Let me know how you make out... If you have no luck I might have to take a look at it.
Old Feb 8, 2010 | 05:48 PM
crueman's Avatar
Lol it's ok....
i'll let ya know
Old Feb 8, 2010 | 05:58 PM
riverviewguy's Avatar
i had the same problem with my 07 ss/sc. it could be one of a couple things. the dealer checked it out and said the airbox was installed improperly. it was revving from 500-3000.it might also be the catalytic converter is plugged up. just got a recall from gm about that. and it could just be that it hunts at idle. mine does that all the time, but they told me that might happen when its modified.and that's all i know. good luck
Old Feb 8, 2010 | 06:12 PM
krishansheanh's Avatar
install an oil catch can. theres a sticky somewhere.
read this
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/idle-problem-cure-finally-116051/
Old Feb 8, 2010 | 06:33 PM
aero_terrio's Avatar
This time of year could just be some condensation in your fuel system, run some gas line water remover through in your next tank of gas, could clear things right up.
Old Feb 8, 2010 | 08:14 PM
MissyMac's Avatar
this. been happening to a few people i talk to
Old Feb 9, 2010 | 11:37 AM
crueman's Avatar
apparently it was the CAI, it was soaked. hopefully no more issues
Old Feb 9, 2010 | 12:09 PM
FloDamien07's Avatar
Wow u guys have pieces of **** intakes than...Our NEVER did that nor did we ever have a problem with the intake soaking up water into the filter..u better make sure 100% that is the problem.And we lived in Nova Scotia before and had that car though every snow storm and down pours while we were in nova scotia
Old Feb 9, 2010 | 12:20 PM
Your intake was better because why???? All intakes are generally the same and mount in the same spot.
Crueman....I would get a k&n oiled filter or a hydro shield to put over your filter.
Old Feb 9, 2010 | 11:18 PM
crueman's Avatar
Thumbs up
the tech's put the car on the computer and the code was a mass air issue, so they looked at the intake, which is a k & n, and seen it was soaked, they dried it out and no more problem, they also found a bad clutch switch which is being replaced tomorrow. had the car out for a good run tonight and no issues at all, so i think it's fixed.https://www.cobaltss.net/forums/imag...lies/smile.gif
Old Feb 9, 2010 | 11:25 PM
skatin_boarding's Avatar
Sounds like the maf got wet. Get the hydro shield that was recommended to stop it in the future.
