rim prepping
Old Apr 3, 2011 | 10:29 AM
smithers80's Avatar
rim prepping
I'm gonna try the task of redoing the tc rims i just bought. Going to start fresh and use aircraft stripper remove all old paint. The question i gotta ask, is what type of sandpaper should i use on minor rash?
Old Apr 4, 2011 | 04:48 PM
pykie's Avatar
minor rash depending on how deep id say 120, i used 80 on a dremel tool on my buddies, then worked my way up to 320, hit them with a primer, sanded the primer 600, then 800 then painted base/clear and they turned out awesome
thought i had pics of it as i went along but this is all i have.
they are choise nut brown metalic
also tires were taken off the rims when i did this
Old Apr 4, 2011 | 07:59 PM
KillahB's Avatar
Just did the same process to my SC rims. It was quite a bit of work. I used Circa 1850 Paint stripper I got from Home Hardware. This brought it down to black paint. The black paint I took off with a wire brush on a angle grinder, the wire brush I chose was quite soft to prevent any deep scoring on the aluminum. After all the paint was off the rims I used 80 grit sand paper to remove curb rash and 120 grit to take out the minor swirl marks left from the wire brush.
I worked my way up to 600 grit to make sure the surface was free of any visible imperfections.
I'm still waiting to paint them. Just need to get some money together. The move to ontario was expensive. Not to mention my car is at the body shop for the next 4 days. I got a Lancer as a rental.
Old Apr 4, 2011 | 08:02 PM
KillahB's Avatar
Before.
After,
The rental
bigdeertz
Nov 17, 2016 09:41 AM
jcalvin1126
Oct 26, 2015 12:31 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Dirtybutwhole
Sep 26, 2015 03:29 PM
Redspire
Sep 16, 2015 07:08 AM
