Canadian North Pacific AK, British Columbia, Yukon [regional map]
Meth?
Old Apr 4, 2012 | 10:08 PM
cavfiredesire's Avatar
Meth?
Looking at picking up a meth/water injection kit and wondering if there is a local place to pick meth up locally.
If you got a idea on price even better!
Old Apr 4, 2012 | 11:42 PM
Sharkey's Avatar
i use methylhydrate, it 99.9% pure alcohol. i buy it from canadian tire for $8/gallon
Old Apr 5, 2012 | 08:01 AM
the owner of snow performance ( the water/meth kit i use ) told me he'd love to sell me boost juice but for much cheaper he told me through emails to use washerfluid and a bottle of yellow heet for the same effect. been using it for 40k miles now that way
Old Apr 6, 2012 | 01:55 AM
Sharkey's Avatar
the problem with washer fluid is it turns everything blue. for the cost of a gallon of washer fluid and a bottle of heet you can buy pure methylhydrate and mix it 50/50 yourself, and nothing turns blue.
or find a vp fuel dealer and buy 5 gallons of it, itll be cheapest
Old Apr 6, 2012 | 02:41 AM
This is true. The blue doesn't hurt anything tho. I have pics of my rotors and lower intake manifold showing that tho lol
Old Apr 8, 2012 | 01:40 PM
I found Mopac carries Boost Juice for $13 /gal but for the amount I want to use I think ill look into the methlhydrate deal.
Old Apr 8, 2012 | 02:23 PM
Heres mine after 40k miles on meth
Everything runs fine
Note blower has 92k on it, meth for the past 40k and coating is still 100% intact
Old Apr 9, 2012 | 09:57 AM
Cam g's Avatar
I have yet to install my meth kit.. But anyone and everyone I talk to says methyl hydrate mix 50/50 works good.. Washer fluid works great if you are down at the track and run out but I hear it doesn't work aaasss good as the actual stuff.. Boost juice... It's more expensive but if U have the cash and wanna go that route that's your call.. The methyl hydrate is probably closest to the best and the cheapest.
Cavfire.. Where are you getting tuned?
Old Apr 22, 2012 | 10:28 PM
I think im going to give Evolution a shot. They have done my friends supercharged cav as well so once I get everything lined up, I cant wait to get off this crappy GM tune...
Intercooler ordered so ill be doing that next week...cant wait!
Old Apr 23, 2012 | 03:33 PM
Cam g's Avatar
Yeah evolution is where I'm gonna go too I think
Old Apr 23, 2012 | 09:17 PM
Well they got 232hp or so out of my friends cav on the stock pulley and no intercooling what so ever.
He has a completely stock motor aside from LZM cams and a balance shaft delete kit, L61 Pacesetter header and exhaust.
Not bad numbers considering.
He is going to install a 2.8 ring and be intercooled along with a LSJ pacesetter so the numbers should rise alot.
Old Apr 23, 2012 | 09:41 PM
Sharkey's Avatar
it will rise, till it breaks a piston.
Old Apr 25, 2012 | 10:04 PM
I believe thats his plan......go till it breaks. I told him that a 2.8 is pushing it. I may give it a shot when I have another dd and meth.
Old Apr 25, 2012 | 10:35 PM
Sharkey's Avatar
if there is any slight bit of detonation at those sorts of boost levels in a 2.2l, its going to break a piston. i found with the 2.2l with a turbo it was happy with 8psi, keeping the timing decent and shooting for 11.5:1afr. 10psi, got a touch of knock, popped a piston. tried again, richening it up a touch and less timing, ran 10-12psi fine, but it didnt have any more power than 8psi. when the gm build book says the 2.2l can withstand 250hp on stock pistons, i believe it, thats around what it was putting out.
id save yourselves a cylinder head and either toss a set of pistons into it or keep the boost down. when it does break a pistons (with a 2.8 pulley its when, not if) it will trash the head. trust me, ive got 4 of them in my basement that are scrap because of broken pistons.
Old Apr 28, 2012 | 01:39 PM
Oh I ully believe you. I wont be doing it anytime soon if ever. I may not bother and buy a lnf instead.
I may jut get a 3" pulley and call it good for a dd. The limits of the 2.2 bother me without having to build it.
And im frankly paranoid about getting a crap rebuild from a machine shop that doesnt know how to build these motors correctly.
I have a spare block just sitting here.
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
