1990 Eagle Talon Tsi
Chicago area
5 Speed manual transmission
123,XXX miles
Black
FWD
Some details:
This is a project car. I bought the car at the beginning of the year with intentions to fix it up and have fun car/side project. Due to my back, I am no longer able to put the time and love that’s needed into this machine. I have replaced quite a few parts on it already and the motor is slightly rebuilt with some head work, new Mitsu 4 layer head gasket, new alternator, some new hoses and vacuum lines, new 2nd gen exhaust manifold, new stock intercooler hoses and side mount intercooler with stock blow off valve, new throttle body gasket, new J pipe gasket, new exhaust manifold gasket, new stock 450cc injectors, new taillights, and a couple of goodies. There is a new battery, the timing belt and water pump was recently done, and has cross drilled rotors. But there are still some issues that need to be worked out. It needs a new O2 sensor, knock sensor, couple of minor body dents, a fresh paint job, some exhaust manifold studs, power steering leaks, a vacume leak, and a small hole of rust on rear quarter panel. Overall the motor is definetly still good and it definitely pulls hard and has the stock 14b TD05 H turbo.
To sweeten the deal I will leave in my AEM digital boost gauge, an Aeromotive adjustable fuel pressure regulator, and will throw in 2 different front mount intercoolers. This alone is about 500$ in parts.
I want 1500$. Honestly I will go lower, I need this thing gone.
You can reach me at 708-two eight five-3130, call or text anytime and if I don’t answer right away, I will get back to you within 24 hours.
Pics:
123,XXX miles
Black
FWD
Some details:
Pics:
