1991 Eclipse GS turbo FS, Minnesota
Old Mar 29, 2009 | 11:20 PM
Ryze's Avatar
Pretty much a pre-sale for this car. I cannot officially sell the car until my ION is able to be back on the road, (which should be by Wednesday this week, Friday by the latest)
But I am throwing this up now because I have the time to do it now.
1991 Mistubishi Eclipse GS Turbo, FWD, turbo, 5 speed manual. 131,532 miles. I am the 3rd owner that I know of this vehicle, I bought it from an older gentleman that did not want to drive it no more (more on this later). He bought it in 1996 with 40k on it. at ~70k the timing belt broke, and he had it fixed professionally including all the damage done to the head. He continued to drive it until about ~124k when I bought it. He is a customer of mine at my shop. He had some problems with it and didn't want to fix it.
Car is completely stock, un-modified. I drove this car all winter, I never had a major problem with it. I had a few minor with/maintenance work that was needed to be done, but is typical with a car of this age. I managed to get 36mpg driving to Iowa in -5 degree weather.
Since I have owned this car I
Changed the trans fluid with Syncromesh
fixed 2 brake lines that broke
re-surfaced the front rotors
balanced the tires
New tie rod ends,
aligned
and did oil changes.
The good about this car
Completely stock un-modified strong130k mile engine
Everything works
Power locks
Power windows
Sunroof
Boosts 12psi NO problem.
Does not burn oil. Checked very often, I have never had to add oil in between oil changes
Does not loose coolant.
When the vehicle was brought to me it had a coolant leak, I found that the radiator was leaking slightly. He didn't want to put money into this car, and took it home. He ended up putting stop leak into it (doh!!) But it seemed to work, I have yet to replace the radiator and it has not lost a drop of coolant all winter
Good tires, replaced in pairs at least 70% left on all 4 tires.
Transmissions shifts smooth
Quiet, just replaced the rusted muffler, with an aftermarket OE replacement muffler (non dual tip like the stock)
Clean black interior
Aftermarket stereo, and all the speakers work
Great gas mileage
The bad about this car
No power steering. The high pressure line is leaking near the rack, I didn't want to fix this problem so I took the PS belt off, so the pump would not be damaged.
Could use rear brake rotors
One rim has a slight bend in it, causes a slight vibration in the steering wheel, but the tire/rim balanced out
Bottom half of driver dash vynal is peeling away.
No catalytic converter removed due to being clogged (exhaust is still quiet and other wise stock)
Body has rust (has been a Minnesota, winter driven car, most if not all of its life)
hatch struts to not work
VIN # 4a3cs54u4me029167
Asking $2200 or best offer
Located in Blaine, Minnesota
On to the pictures
Old Mar 29, 2009 | 11:23 PM
2007victoryred's Avatar
Good luck on the sale!
Old Mar 29, 2009 | 11:32 PM
Ryze's Avatar
Thank you
Old Mar 31, 2009 | 10:35 PM
TitoBandito's Avatar
Damn, if it wasn't so far away, I might be able to snag it, Goodluck
Old Mar 31, 2009 | 10:39 PM
Ryze's Avatar
its pending sale, should be gone thursday
Old Mar 31, 2009 | 10:47 PM
steddy2112's Avatar
:drool:
If I only had the money
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
