For Sale 1995 Z28 Camaro 383 Stroker!
Old Oct 26, 2012 | 01:53 PM
rcarr0327's Avatar
Seller: Adam and Calvin
Contact: PM me and I will give you their phone number or you can get from Craigslist ad
Price: $10,000 or trade
Hey everyone, for sale is my friends 95 Z28 Camaro, bored and stroked to a 383. They are looking for a sale or trade for something they can drive year round. So i told them that I can help and maybe some cobalt guys could help them out Has 86,000 miles on body, Miles on motor coming soon.
Engine
-New OEM Oil Pan
-New GM high pressure oil pumps
-383 stroker kit from SCAT, FORGED Pistons, FORGED Rods, FORGED Crankshaft.
-Studded Main Caps, New main caps, and new main bearings from CLEVITE
- COMP CAMS CAMSHAFT SPECS >>>> COMP Cams: Xtreme Energy™ 276HR-14 <BR> For Use w/ LT1 Modified Computer
-New cam bearings
-Double roller timing chain and cogs, CLCYONES
-WATER PUMP DELETE, ELECTRIC WATER PUMP INSTALLED
-Comp Cams short travel roller hydraulic lifters.
- Seamless chromemoly heat-treated Pushrods
-Stock LT1 ported heads, 3 angle valve job, resurfaced
- ARP Head studs
-Comp Cams double beehive valve springs
-Comp Cams Pro Magnum™ Rocker Arms ( The strongest and most light weight for the LT1)
-Aluminum valve covers made by Canton
- 10.1 compression starter from power masters
-42lb frank injectors
-New adjustable fuel regulator
-New 90psi fuel pump
-Forged hays steel flywheel
-Centerforce dual friction clutch
-SLP dual intake
-2.5 custom mandrel bend steel exhaust.
-Last is the PCM has been custom tuned for this engine by Ion Sulton
Transmission:
-Stock T56 Borg Warner Transmission
-Fully rebuilt
Brakes and driveline:
-Front drilled and slotted Stainless steel rotors, and akebono brake pads (Less than 1000 miles on them)
-Rear drilled and slotted zinc coated steel rotors, and akebono brake pads (less than 1000 miles on them)
-Rebuilt rear axle, (Stock specifications)
Suspension / Other:
- New rear KYB Shocks and Coils
- New front and rear Passenger and Driver side wheel bearings
- New Denzo O2 sensors
-New Mass Airflow sensor
-New throttle position sensor
-New 84 month carquest battery
-New alternator
-New Aluminum radiator
Wheels:
Fronts: 255/50/16 Indy 500 summer tires made by firestone BRAND NEW
Rear: 265/55/16 BF GoodRich T/A Drag Radials BRAND NEW
For pictures and videos you can visit the craigslist ad, thanks for looking!
1995 Camaro Z28 383 Stoker
Sean Cummings
Sep 11, 2015 09:35 PM
Zefhix
Nov 15, 2009 06:00 PM
Eddie
Feb 4, 2006 01:21 AM
3fo893013L
Oct 29, 2005 03:05 PM
CamaroMuscleZ28
Apr 28, 2005 06:08 PM
