For Sale 2005 ION Red Line
2005 ION Red Line
I am selling my 2005 ION Red Line. The car is black with blue Recaro seats and polished wheels. I bought the car with 38,000 miles from the original owner 3 years ago and it now has about 109k miles. The car has been maintained properly by me. The car has been modified a bit and includes the following parts installed:
60lb fuel injectors
Smoothflow 2.8" and 3.0" supercharger pullies
Clear Image Automotive Header and 3" downpipe
2.5" catback exhaust (slight exhaust leak at catback to downpipe flange)
S&B air filter
2006 G85 LSD transmission with 70k miles (installed at 95k)
GM Performance clutch upgrade (installed at 95k)
New OEM Flywheel (installed at 95k)
New Clutch Pipe (installed at 95k)
New Upgrade Throw Out Bearing (installed at 95k)
ZZ Performance adjustable clutch master cylinder
New axle seals
B&M Short Throw shifter
New GM Shift Cables
LNF Shift Bracket
Turbo Tech Racing motor mounts
New Crank Position Sensor
New Starter
New Ignition Swtich Module
Dyno Tuned at ZZPerformance in Grand Rapids
2009 FE5 front struts
2009 FE5 rear shocks
Progress lowering springs
Progress Rear Sway Bar
Moog front sway bar end links
Over The Top Performance steering rack spacers
NewSouth dual guage pod on steering column
PLX Wideband O2 sensor
Aeroforce Interceptor Scan Gauge
New (revised) Timing Chain Tensioner
ZZ Performance Stage 2 Heat Exchanger
Dual Pass Intercooler end plate
New Front Rotors
New Hawk HPS front pads
Pioneer AVH-P3100DVD headunit
The interior is in great shape, the Recaro's have no tears or rips.
The front bumper should be replaced, it was beat up during the 3 winters that I drove the car in. It has the typical scratches here and there for a 6 year old car driven everyday.
I'm looking to get around $7,500 for the car.
60lb fuel injectors
S&B air filter
New axle seals
New GM Shift Cables
LNF Shift Bracket
New Starter
New Front Rotors
im on deployment right now and the computer wont let me see the pics...can you send some to navyatc89@gmail.com? thanks!
