Finally made a decision to put it up for sale so here it is:
2007 Chevrolet Cobalt SS/SC Supercharged 2.0L – Silver
Has >24,000 miles. Rarely driven, unlikely to increase.
$11,000 or best offer, serious offers ONLY, can't buy a better ride!
Pretty much all of the ZZPeformance catalog parts are on this vehicle. All work done by myself and I am a trained professional mechanic.
It has never been driven in the winter and never seen snow
Always garage kept and been always covered with a car cover
Rust free and also has the rubber undercoating
Professionally detailed.
Carfax available on demand.
Overall, excellent condition!
Interior 10/10
Exterior 9/10
OEM wheels with brand new Bridgestone pole position tires on it. Mounted 5/2/17.
Rotors are almost new, The pads have an estimated 85% of life left.
Fresh oil in the motor and have always used full synthetic MOBIL 1 oil
Tuned by Superstreet Performance
Strictly E85 for fuel and dynoed at 312WHP with a rev limiter of 7200
Clean title
Interior:
Black leather interior with the SS badge in the seats
Both heated front seats
AFR gauge and boost gauge
32% window tint
This car is tastefully modified with many modification made
here is the list:
Engine:
2.0L Supercharged motor with all new gaskets for the build have been replaced.
LS4 throttle body
ZZP 3in Cold air intake
M62 supercharger Ported and Polished by MAPerformance. Matched to LS4 throttle body.
ZZP 2.7 pulley
E85 80# injectors (also have Petrol 60#, and 42# injectors)
Upgraded fuel pump
ZZP ported and polished head.
-82lb Ecotec valve springs and titanium retainers
-New updated lash adjusters
-APR Head studs installed
ZZP Stage 2 supercharged cams
New timing chain tensioner
Neutral balance shafts
ATI overdrive balancer
ZZP Motor mounts
Adjustable belt tensioner
Phenolic Intake Manifold spacer
ZZP shorty header
ZZP 3” inch exhaust all the way back with downpipe
ZZP option b supercharger cooling kit
S3 Stealth heat exchanger
4 Bar map sensor
Suspension:
Slotted and drilled front rotors
Stance coilovers
Rear sway bar
Transmission:
Centerforce dual friction clutch
Short throw shifter
Factory LSD
You can contact me by email or phone if you have any questions: aaron.smieja89@gmail.com
Phone number 651-470-4597
Reason: Changed price
Thanks man, i really enjoy the center force clutch, its not too heavy of a clutch and yes it does have a lightweight aluminum flywheel, its just the dual friction clutch and its perfect for my power level on the car and I'm sure it can hold more, when i got the clutch it was at a decent price compared to the other ones.
I bought one on amazon brand new in box for 197$ lmao
just as a spare
thanks for the response
glws
The original price was 12k, I wanted to add or best offer to the ad cause I didn't have it posted, now it's at 11k or best offer as you can see in the ad posting, the price never went up, it actually went down as you can see.
I see....
I was just seeing your last post which looked like it went up... my bad. It is very tempting but I am looking for an 09 or 10 in Ultra silver Metallic
